Wheel bearing problem
Billing
PostPosted: 14:43 - 08 Aug 2011    Post subject: Wheel bearing problem Reply with quote
Hi all,
Just got delivery of my 17 inch rear wheel, and it's as I feared, the outer race is spinning in it's seat. I was thinking of trying to use some bearing lock on it, just as a temporary measure as the bike will only be used every now and again (track bike)
Is that a bad idea, or will I be able to get away with it? The bearing is a 6004 (20X42X12mm) whats the next size up so I can get it machined out and do it properly please?
Fizzer Thou
PostPosted: 14:48 - 08 Aug 2011    Post subject: Reply with quote
You can get bearing lock from Loctite.It is pretty good stuff if you follow the use instructions.I would stake the bearing housing in several places once the bearing is in place.Then make sure that the spacers fit correctly and securely.
Always have a 'Plan B'
PostPosted: 14:52 - 08 Aug 2011    Post subject: Reply with quote
Doing it properly probably would entail building the wheel up with weld and remachining the bearing housing. Or machining it out to take a sleeve.
Getting a bearing that has a larger external diameter but the same internal diameter and depth might well not be easy.
Billing
PostPosted: 15:09 - 08 Aug 2011    Post subject: Reply with quote
I had seen it, so wondered if anyone had used it before in this application before I spend out and it's useless. The only problem with staking is that it'll ruin the wheel after a couple of changes, I suppose as I won't be changing them often it won't be such a problem.
That does sound like a massive ballache to be fair Keith, building up a 12mm stack of weld will take a LOT of time and money.
The sleeve sounds better, bore the hole out to take some thin wall tubing of the correct I/D then weld it to the wheel, would that work maybe?
I'll give a local place a bell, see if they can help me out Smile thanks guys.
PostPosted: 15:18 - 08 Aug 2011    Post subject: Reply with quote
You would only need to build it up by a mm or so before cutting it down. All you need is enough extra meat on it to take up the wear.
With a sleeve you would be best off just making up a an appropriate sleeve that is a tight fit, then use a strong loctite to locate it. Otherwise you are going to have to use an alloy sleeve to weld to the wheel and then clean it up afterwards.
0ddball
PostPosted: 15:28 - 08 Aug 2011    Post subject: Reply with quote
There is a 20x45x12 but i don't think it's a standard size. Honda use it in various front wheels.
Unless it's very loose, i.e just drops out, i'd be tempted to just use bearing lock. If you use a quality bearing you aren't going to be changing it again for years anyway.
ZXR750L
Billing
PostPosted: 16:44 - 08 Aug 2011    Post subject: Reply with quote
it doesn't drop out, but I did manage to just pry it out with a screwdriver, so think that the odd sized one might be a good idea, although if the loctite will fix it temporarily and cheaply I think it might be worth a go Thumbs Up Will also have a word with my mates dad who could probably get any of the above options done and see if he can help.
Billing
PostPosted: 16:47 - 09 Aug 2011    Post subject: Reply with quote
I went to grab some oil for the VFR, and saw a packet of loctite stud and bearing lock, tried it out just as a temporary measure, and it seems to have held for now, but I'll be keeping an eye on it from now on.
SoND
PostPosted: 22:56 - 11 Aug 2011    Post subject: Reply with quote
How loose is loose? Loctite alone to glue it in won't last, it needs to be an interference fit i.e hammered/pressed in.
A beer can might be the right sort of thickness for a tight sleeve, if it's too thick a little bit of sanding will open it up pretty quickly. Keep the sanding even and check the fit often, last thing you want is to make it too loose again. To keep track of how much you're taking off you can draw a line, with a marker, around the center and sand until it comes off. 240 grit is a good choice.
The last post was made 15 years, 78 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.73 - MySQL Queries: 13 - Page Size: 64.15 Kb
