yamaha rxs100 - skipping noise
shleppy
PostPosted: 17:38 - 08 Aug 2011    Post subject: yamaha rxs100 - skipping noise Reply with quote
i noticed this a few days ago, as you pull away the bike judders and makes a skipping noise, sounds like the same area as the front sprocket but with the cover off there is plenty of meat on the teeth and the chain doesn't skip as it turns.
once the cover is off the clutch is no longer active as the cable runs through the sprocket cover to a lever. i had to bump the bike without the clutch; starting like this the problem doesn't seem to happen at all.
Would the problem be the clutch? or maybe gears skipping - but i dont have a problem once the bike is moving or when i change gear?
Dr. Quack This post is not being displayed because the poster has bad karma. Unhide this post / all posts.
The last post was made 15 years, 42 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.84 - MySQL Queries: 13 - Page Size: 36.18 Kb
