Jittery when braking
shereen
PostPosted: 09:35 - 09 Aug 2011    Post subject: Jittery when braking Reply with quote
VFR400 NC30 When braking hard the bike 'jitters' through the handlebars. Took it to garage as I was concerned that the head bearings were knackered. Mechanic said it was the brake pads rattling inside the callipers and nothing I can do about it...... I'm not convince.
Thoughts?
PostPosted: 09:43 - 09 Aug 2011    Post subject: Re: Jittery when braking Reply with quote
Wouldn't expect that under hard braking.
Check the wheel bearings, which is the most likely cause of that sensation in my experience.
Skudd
PostPosted: 10:27 - 09 Aug 2011    Post subject: Reply with quote
I had the same thing and changed my pads which cured the problem.
if it is a pulse then it will be the disc.
shereen
PostPosted: 10:32 - 09 Aug 2011    Post subject: Reply with quote
The pads were new about 500 mile ago, should I still try changing them? Definitely a 'jitter' and its very annoying Evil or Very Mad
The mechanic pissed me off as he didn't even bother riding the bike to see what the problem was himself. Sad
PostPosted: 10:46 - 09 Aug 2011    Post subject: Reply with quote
Good point - generally I'd expect that to come more through the brake lever, but does tend to have a general effect on the front end.
PostPosted: 10:48 - 09 Aug 2011    Post subject: Reply with quote
Get your hands down there Wink
See if the front wheel has any play at all, grab a friend to tilt the bike on its stand and lift the front wheel, check the play in the bearings. While you are there you can check the head bearings also Thumbs Up
Possibly check your discs? mine doesnt do what you state, but I get odd knocking from tapping from the front Laughing one of the button looking things on my disc is moving.. the rest are solid Laughing
shereen
PostPosted: 10:52 - 09 Aug 2011    Post subject: Reply with quote
He said the front disc had a slight warp in it but he said it is nothing to worrying about as its only very slight.
I feel like im going to end up spending lots of money trying to rectify this problem Sick
PostPosted: 10:54 - 09 Aug 2011    Post subject: Reply with quote
disk or bearings, neither are too expensive. Thumbs Up
shereen
PostPosted: 10:56 - 09 Aug 2011    Post subject: Reply with quote
I have wavy ones! doh!!
PostPosted: 10:59 - 09 Aug 2011    Post subject: Reply with quote
Are the disks stock ones? Had a cast iron disk which caused a load of judder on the brakes without being warped (no pulsing through the lever) after the pads had stuck to the disk (put away wet). Point where the pads had stuck grabbed the pads.
jimbothe
PostPosted: 12:57 - 09 Aug 2011    Post subject: Reply with quote
The wavey discs on my Gixxer always gave the impression of judder and pulse when they were cold.
Are they waveys like these:
https://i22.photobucket.com/albums/b342/jgillard/Allmymotorslovelyandshiny004.jpg
or are they the knock off cheaper style ones?
Check out our tackle shop on Facebook:
https://www.facebook.com/#!/JklTackle
shereen
PostPosted: 18:09 - 09 Aug 2011    Post subject: Reply with quote
This is mine
https://i959.photobucket.com/albums/ae74/Clearancelines/190155_1897101268835_1280701830_2280141_1885277_n.jpg
It still does it after a 20 mile ride though. I assume it would have warmed up by then?
Im thinking to take it to another garage and see what they come up with. I dont know enough about bikes to check for the wheel bearings etc.
They did check for play in the front end but they said it was ok.
jimbothe
PostPosted: 18:40 - 09 Aug 2011    Post subject: Reply with quote
Yes they should have.
Yes but no. Go in with some idea of what the problem is or where it could possibly lay so they don't try to walk all over you and charge you for items/service thats not needed.
Can't a mate, neighbour, boyfriend etc help you with it?
Did you see them check it or did they tell you they had?
Did they check for wheel bearing or headstock bearings or both?
Just another thing, how is your tyre? Can't quite see from the pic but is it a Bridgestone BT series? If so is it wearing evenly? Is it inflated correctly?
PostPosted: 19:11 - 09 Aug 2011    Post subject: Reply with quote
Mmm, those disks look like they have fairly major cutouts at the edge, both in how far they go round and how deep they are compared to the position of the pads.
Wonder if the pads are rocking off the disk as they outer edge goes over the cutouts.
shereen
PostPosted: 19:36 - 09 Aug 2011    Post subject: Reply with quote
I saw him bounce the front of the bike up and down, I didnt see/dont know if he checked the wheel bearings. I told him I thought it was the head bearings so I would assume he checked for that.
It is indeed a Bridgestone BT, it is worn evenly and I only checked the pressures the other day, they were both 32 psi, I knocked them up to 33psi which is the recommended pressure for my bike.
jimbothe
PostPosted: 19:41 - 09 Aug 2011    Post subject: Reply with quote
I forgot to ask earlier. How long have they been jittery for? Recently or since you had the pads done?
As Keith says, your discs have very large 'wavy' sections. Did you put these on or were they already on there?
Just trying to establish a 'when' factor and to determine if it's something recent thats started it. For all we know it could have had the jitter from the day you purchased it Laughing
shereen
PostPosted: 19:45 - 09 Aug 2011    Post subject: Reply with quote
Well it wasnt ridden for a few months by myself when I 1st got it. My ex (who rode it 1st) said it didnt have the jitter. But it has had it for as long as I can remember.
jimbothe
PostPosted: 19:53 - 09 Aug 2011    Post subject: Reply with quote
I would be replacing the discs and pads as said above.
Wavy discs are somewhat a fad for your average road going commuter or weekend joy rides . I'm not saying they don't work because they do, but in my experience I've found they only work their best when piping hot as it reduces the brake fade over standard discs. You really have to be riding hard to get the best use out of wavy's. Thats what I found when I fitted them to my Gixxer.
shereen
PostPosted: 20:09 - 09 Aug 2011    Post subject: Reply with quote
Would that cause the jitter though? It feels like its coming through the forks
jimbothe
PostPosted: 21:07 - 09 Aug 2011    Post subject: Reply with quote
Well it's hard to say without actually seeing the bike and feeling for movement but you said the mechanics checked for play and didn't find any. If they couldn't find any then it doesn't really leave much on the front end. You could remove the wheel and check the spindle for uneven wear but this is unlikely to cause a jitter.
Other than that, broken spring, worn internal bushes?
Drew This post is not being displayed because the poster is banned. Unhide this post / all posts.
shereen
PostPosted: 09:26 - 10 Aug 2011    Post subject: Reply with quote
Hmmm, thanks for all the replies.
I think I will pop it into another garage later and see what they think. If they don't know what they are talking about I will change pads/discs and see what happens. I'm keen to get it sorted before I got to France on bike at end of the month so I really should pull my finger out Shocked
Will update with what happens.
Thanks again for every ones advice Thumbs Up
shereen
PostPosted: 16:42 - 17 Aug 2011    Post subject: Reply with quote
Well looks like France is cancelled. Crying or Very sad
Just got back from mechanic -
There is play in the forks, suggests replacing headstock bearing, seals. Fork bushes, seal + new oil. Also need anti rattle shims in the calipers Confused
Total parts £150 Labour £105
And he's not even sure if any of that is the cause of the jitter Sad ffs!
blaaaaaaaaaahhhh!! stupid bike Middle Finger
rant over
PostPosted: 16:57 - 17 Aug 2011    Post subject: Reply with quote
Basically
"I dont know what it is so i'll replace every possible cause on the front end"
Sounds like a nice guy Rolling Eyes
Hes basically changing headstock bearings (you or boyfriend could possibly do that!)
Fork seals, are yours upside down forks? I dont think they are... they are EASY to do if they are right way up.
Im still not sure its that..unless your forks are so soft.
£255 for head bearings and fork seals.. This is your anus ( O )
I bought fork seals, dust seals, braided lines, pads all round and some other bits and bobs for £79... im sure headstock bearings arent overly expensive (probably a pig to do on your bike though)
0l0dom0l0
PostPosted: 17:30 - 17 Aug 2011    Post subject: Reply with quote
It's funny, I've got exactly the same problem with my 93 CBR 600. It jitters exactly as you describe under heavy braking only. Not a warped disc as there isn't a pulse through the lever.
I'm thinking it was because I was bottoming out the forks as they were shot. I'm in the process of changing them over so haven't had a chance to test them yet.
Mine wasn't wheel bearings or anything like that as it passed the MOT and I watched the guy check it all.
Possible it was my pads but not to sure.
Are you forks spongy? Could be that they need a referb or something.
The last post was made 15 years, 23 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.59 - MySQL Queries: 13 - Page Size: 134.3 Kb
