Air in shocks?
pits
PostPosted: 22:02 - 09 Aug 2011    Post subject: Air in shocks? Reply with quote
Seem to have an issue with my forks on my Duke, and I have no idea how or what is happening, but I think I am getting air in my shocks, or something is wrong with them.
At the moment I have no damping on my suspension, you try and compress the forks, nothing happens, they just don't move if you push down on them.
Now I believe they are filling the left over void with air, or something is mega wrong with my rebound on them, but it did this last week, and when I undid the top caps, a lot of air shot out of one, which leads me to believe there is air getting in.
Is this possible? I am guessing that it would be getting in through the lower dust seals? They are the Showa units, non adjustable.
If I am honest I have no idea Mr. Green Thumbs Up
PostPosted: 22:16 - 09 Aug 2011    Post subject: Reply with quote
Should be a bit of air in there. Acts as a spring. When lightly compressed and with the valve released that air will come out.
Have they suddenly stopped moving?
PostPosted: 22:18 - 09 Aug 2011    Post subject: Reply with quote
Many forks are air filled, they'll usually have a valve on them for adjusting/re-filling.
If they are not moving at all that won't be because of air in them because the air would compress allowing the fork to move.
pits
PostPosted: 22:24 - 09 Aug 2011    Post subject: Reply with quote
No it's more gradual.
Say I go downstairs now and pop the top caps open enough past the little rubber seal on top, then do them up again I will have suspension back, then as I ride the suspension gets gradually harder and harder, till it is back to how it is now, rock hard, you feel every bump in the road, and when cornering the front washes out slightly.
First time it went rock hard I took the top caps completely off to have a look at what was inside, and everything moved fine after I had done it and put it back together, but the left hand shock released a lot of air when I undid it.
I took it out, did about 60 miles and it was ok but getting stiffer, then 24 miles after that it was back to hard again, so I undid top caps ever so slightly to break the seal and it brought suspension back, but now I have done 24 miles they are rock solid, there is no pushing them down with the front brake on and you pushing them, they just don't move at all.
I have no idea if undoing the top caps will do temp fix it again, but obviously I want to fix it so it doesn't do it all, wondering if the dust seals are doing it?
The top caps have the rubber O ring which both seem good and feel ok, not dry etc, and the clip ons also bolt around the join so that helps eliminate the air from the top.
I really don't know if I am honest.
sickpup
Old Timer
PostPosted: 22:27 - 09 Aug 2011    Post subject: Reply with quote
I would suggest this is actually a damper problem, possibly a screwed shim stack not letting oil through on the compression stroke so when you accelerate the forks extend to their full length but cannot compress again.
PostPosted: 22:29 - 09 Aug 2011    Post subject: Reply with quote
Which bike is it?
As Pete says, the air would still compress. If the air is really building up then I would suspect it is a symptom rather than a cause. Are the forks extending fully? If rebound damping was somehow blocked then the forks wouldn't return to full length properly and that would probably pressurise the air.
But that is VERY much a guess without knowing the forks and having a look at how that set work.
PostPosted: 00:05 - 10 Aug 2011    Post subject: Reply with quote
I'm with Sickpup it sounds like there's no oil passing on compression. What has caused this to start to happen? Have you had the seals done or any other work?
pits
PostPosted: 08:28 - 10 Aug 2011    Post subject: Reply with quote
That is what I thought, air can be compressed.
shocks were working properly, I put cable ties on them took it out for a ride, and I was getting decent travel on the front, now the front is up at the top and they just wont go back down, if I push them.
Had no work done to them, the seals aren't leaking fluid, there is oil in the forks as well.
Bike is a 2000 Ducati 750SSIE with the non adjustable Showa front end.
Sickpup, I see what you are saying, but I don't think you're right, I need to consult a trainee mechanic who has only touched one set of shocks in his life Laughing Laughing Laughing Laughing This last bit is a joke, anyone wondering, read the GT550 air shocks thread, rather amusing.
PostPosted: 09:32 - 10 Aug 2011    Post subject: Reply with quote
If you drain the oil they will have a lovely bit of bounce Very Happy
sickpup
Old Timer
PostPosted: 21:30 - 10 Aug 2011    Post subject: Reply with quote
The only time I have seen this before was a set of GSXR600 upside down forks where someone had bent the damper rod while changing the forks seals.
That or the shim stack thing I mentioned earlier.
sickpup
Old Timer
PostPosted: 21:45 - 10 Aug 2011    Post subject: Reply with quote
As this problem intrigues me heres a picture from Showa of what the inside of your fork probably looks like...
https://www.showa1.com/en/product/motorcycle/img/detail_shock_touritsu.jpg
Which may give you an idea of what could go wrong, not much.
pits
PostPosted: 21:54 - 10 Aug 2011    Post subject: Reply with quote
Well, I have left it and checked it this morning and I have some suspension back.
What I can see in my mind is that there is a build up of pressure in the forks, and it can't go anywhere quick enough to be removed, but that pressure can drain over night.
I have no idea really, I mean there is no oil on the shiny bits, and when they have been left or had the top caps removed, they work again, and I haven't had any work or dicking about with them until now, time for a garage me thinks Crying or Very sad
pits
PostPosted: 10:02 - 19 Sep 2011    Post subject: Reply with quote
Got the bike back now from having a few jobs done, found nothing wrong with the forks, but rebuilt them.
Reckoned the oil was too heavy at 10w, still not sure on that diagnosis as it had been fine sine April when I bought it then went from riding lovely to instant riding like a big bag of crap.
New seals, and the oil replaced with 5w, which I think may be a bit too thin, the bike rides lovely, but the arse end is really stiff now which is fine, but the front is murdering my wrists and you can feel every single bump in the whole road, might try dropping 2psi of pressure out of the front tyre and the rear, but because I weigh nothing I don't think I am putting enough weight on the bike for the thinner oil, may take it back and see if I can back to 10w depending how it continues to ride, at the moment, I don't like it.
That said, I appear to be having no problems on the front end, road around 150 miles over the course of Friday and Saturday, all different roads, even some really bad country back roads and all seems good.
Again, just not sure on this oil in the front end, would dropping the tyre pressures help? It is just to stiff for me on the front that I am not as confident in going as low as I used to as I can feel every bump, it feels more stable and doesn't feel like it wants to chuck me off like it did before, but it feels similar as you feel every little stone on the road, and as I said it also destroys my wrists now, still happy though.
PostPosted: 10:21 - 19 Sep 2011    Post subject: Reply with quote
5W oil is thinner and should give a softer ride, with you feeling less bumps. Thicker 10W oil would hammer your wrists even more.
Is the preload on the forks adjustable? If so try running a bit less preload.
Simple terms, the springs control how far the suspension moves while the damping controls how quickly it moves.
The last post was made 14 years, 101 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.84 - MySQL Queries: 13 - Page Size: 86.2 Kb
