Sat navs...
L-Jam
PostPosted: 20:30 - 10 Aug 2011    Post subject: Sat navs... Reply with quote
Alright bromeos.
Looking at getting a motorbike specific sat nav, what are my options? I haven't a clue, prices, why are some 400+ etc... and on a sidenote brackets to fit it. Anyone a bit more experienced in these matters?
Thanks a lot Karma
Journalist, student, egotist.
Deaks
PostPosted: 21:28 - 10 Aug 2011    Post subject: Reply with quote
You essentially have 3 options. Garmin, Tom Tom or the cheap option.
The dedicated bike ones are waterproof, thats why they are £400ish.
The cheap option is buy a car one. Not waterproof but a lot cheaper.
I've got a Garmin 660. Expensive but it is the dogs nuts. And came with the mount and wiring etc.
Suzuki SV650S '04 (09/08-02/11), Triumph Tiger 1050 '07 (02/11 - current).
Live to Ride. Ride to Feel Alive.
temeluchus
PostPosted: 21:57 - 10 Aug 2011    Post subject: Reply with quote
I bought a subs to a sat nav suite for my mobile and wear headphones under my lid.
Skudd
PostPosted: 22:45 - 10 Aug 2011    Post subject: Reply with quote
Garmin +1 Thumbs Up
PostPosted: 00:45 - 11 Aug 2011    Post subject: Reply with quote
TomTom Rider for me, especially the urban with the newer mapping Thumbs Up
neil.
PostPosted: 09:05 - 11 Aug 2011    Post subject: Reply with quote
I have the original TomTom Rider (v1) got it on eBay a few years ago for £150 I think. The mount it came with was dire for two reasons - the sat-nav would vibrate in it too much, arcing across the electrical contacts (4 sprung pins), wearing them away over time. Also, the mount did not hold the sat-nav securely - hence why TomTom released a 'dog lead' attachment in case the sat-nav was thrown out. I bought a Touratech mount for it which is fantastic - makes use of part of the original mount that has the electrical contacts on it but holds the device so much more securely. The mount was much improved in the later versions of the Rider.
https://cbf125rider.files.wordpress.com/2011/06/100_0712.jpg
I have dropped it a few times on to concrete from chest/waist height and it's withstood it just fine. It's also survived 3 years of commuting, wind, rain, ice, snow, hot sun, everything and is still great. I have replaced the battery (as they do die after a few years - that's the nature of lithium ion cells) which was a bit of a pain as you need specific tools for it due to the tamper-proof screws they use, but once inside it's very easy to disconnect and remove the old battery.
I use a Scala Rider FM (with radio) headset, which has also lasted quite well over the years, but is showing signs of being tired now. Having instructions come through in the helmet via bluetooth is really good, and you can also use the Rider as a hands-free phone with your mobile in your pocket. You get the keypad on the screen as well as being able to send/read text messages. All via bluetooth. Traffic reports are useful (downloaded via your phone's data connection every few minutes) as well as speed camera warnings.
koolio
PostPosted: 09:24 - 11 Aug 2011    Post subject: Reply with quote
I've used GPS a lot until I decided to stop using it when on my own.
Grab a map, grab balls, start thinking, planning the route, you actually learn the land.
Reason I stopped using it is because I've been riding in London for years and still don't know the roads due to GPS, now I'm actually learning rather than switching off. Its more fun now.
olionel
PostPosted: 09:36 - 11 Aug 2011    Post subject: Reply with quote
I only use the sat nav when I'm a bit stuck etc or finding a petrol station, supermarket, campsite, hotel etc abroad, or quite like switching "avoid main roads" on and doing some back lanes...
I use a garmin e-Trex HCx, it's meant to be a walking/hiking/mountainbiking gps and comes with a bar mount so easy to attach.
https://buy.garmin.com/shop/shop.do?pID=8703&ra=true
1989 CG125 - Childhood Sweetheart (she got kidnapped by baddies)
1998 ZXR400 - Teenage Love (lasted three years, then she turned lesbian and left me)
2001 XRV750 - Wife Material (still getting to know her but head over heels in love)
PostPosted: 09:55 - 11 Aug 2011    Post subject: Reply with quote
I've been pretty happy with my 660. I did consider the older designs, but the 660 had a few improvements I wanted (ie older bracket apparently suffered off-road).
It was expensive, but I've been using it for a couple of years now in car and bike and still happy with it.
If you've got time to play with your balls, a map's great Wink... but I definitely like the convenience of cutting out a big chunk of prep time, as well as a chunk of "where the *** am I, when you come to the end of the road you thought was your destination".
phonesurgeon
PostPosted: 10:04 - 11 Aug 2011    Post subject: Reply with quote
Being a cheapskate, rather than buy a specific sat nav unit...
I ve downloaded the garmin mobile version Garmin XT on my N95 with the full european maps.
And to fix it to handle bar i ve modified an old car kit, and a cheap nokia charger, power point under seat.
The accuracy is stunning, drove to italy twice(in car), and drove all around, without getting lost.
I have 2 device into one, but the N95 internal gps sometimes can be a pain to get satellite reception!
Easter Bunny
PostPosted: 10:32 - 11 Aug 2011    Post subject: Reply with quote
I used to recommend Tom Tom Rider mainly because of the price and the 2 year warrenty dispite the fact there appears to be a known fault with the rider 2 mount, vibration causes the mount to wear to the stage where there is movement, if nothing is done about this quickly the charging pin wears and then the unit becomes unuseable on the mount throu not charging. As it had a 2 yr warrenty it was getting repaired each time, this happened to me several times and was repaired under the 2 year warrenty once outside the warrenty I ended up using a ciggy lead to the mains point which eventually broke the pin rendering it totally unuseable.
Now even thou this happened I would have still recommended the Rider due to it being nearly half the price of a garmin except now Tom Tom is saying the cradle is now no longer covered on the 2 year warrenty just by the one year guarentee.
If you can afford it buy a Garmin, if you cant buy a car sat nav and mount it in a sandwich box!
L-Jam
PostPosted: 17:21 - 11 Aug 2011    Post subject: Reply with quote
Right so basically I should try and go for an older sat nav, not the brand spanking new models? Can anyone point me a few links please guys? I would use a map but it's my job to get to different places in the welsh valleys quickly and trying to find your way way round there is a fucking nightmare. Cheers for all the help so far guys!
c-m
PostPosted: 18:31 - 11 Aug 2011    Post subject: Reply with quote
If you have a decent phone, just use that, with a ram mount. Perfect.
A bike specific phone might be something like the motorola defy.
Motorcycle headlight bulbs and HIDs
Blogging about my bike and trips
https://ridershandbook.com/
Biker Alex
PostPosted: 18:48 - 11 Aug 2011    Post subject: Reply with quote
If you have an iphone...
I accidently downloaded installious and installed tomtom for free.
And then l managed to mount it for almost nothing.. I looked at the ram mounts, they are £30 but I'm too cheap.
I installed that special velcro mushroom stuff to the headstock and to the back of a 50p phone case. I also got a cig lighter for a £5 so I can power it. The lighter has a waterproof cap, I have to put the phone away when it rains, personally I would not go exploring in the rain anyway. Im sure you could come up with a waterproof bodge for next to nothing. You could also just put it in your pocket and listen to audio instructions.
For me it was an itch to have a sat nav, but only used it once before I got bored of it. Something to consider if you are thinking of buying a £400 sat nav or £30 mount instead of the above.
Paulington
PostPosted: 19:05 - 11 Aug 2011    Post subject: Reply with quote
You cannot 'accidentally' download Installous, it requires entering a new feed through Cydia or similiar and then downloading that feed. Not something you can do 'accidentally'. Rolling Eyes.
I've been using Tom Tom Satnavs for years and prefer them ram mounted to the bike or I'll just sticky-pad it with the mount to the tank (fairings keep it dry) and cable tie it to the GoPro next to it so if it does disconnect, it just hangs off the GoPro.
Sorted. Thumbs Up!
Peirre oBollox
PostPosted: 19:21 - 11 Aug 2011    Post subject: Reply with quote
Garmin have recently launched the streetpilot app for the iphone
https://itunes.apple.com/gb/app/garmin-uk-ireland/id439044354?mt=8
Unfortunately its only UK & ROI at the moment, but I suspect that they`ll launch a european version soon
Dazbo666
PostPosted: 19:53 - 11 Aug 2011    Post subject: Reply with quote
Car satnav, plus tank bag map pocket for me... if only cos I bought the g/f a satnav, only months before she had to sell the car Rolling Eyes
https://img.comet.co.uk/images/prod300/731374.jpg
Word of the day : DILLIGAF
temeluchus
PostPosted: 21:51 - 11 Aug 2011    Post subject: Reply with quote
Most of the mid to upmarket phones are gps equipped. Subscriptions to telenav, wisepilot and the like can be had cheaply.
Almost all recent blackberries, the iphones and most android phones have built in GPS.
PostPosted: 22:21 - 11 Aug 2011    Post subject: Reply with quote
And cheaper phones like the Orange San Francisco (£100) have GPS too these day.
PostPosted: 00:42 - 12 Aug 2011    Post subject: Reply with quote
If you have an android phone, use googles free sat nav. Works fine, I ve used it in the car many times
Hannibal
PostPosted: 09:20 - 12 Aug 2011    Post subject: Reply with quote
I use Ndrive on my Iphone, cost £10, works well. If I'm on the bike I just blue tooth it into my scala, and don't worry about the maps, just listen to the instructions....sometimes I may be moving a bit too rapidly for the sat nav tho' and am past a turning before she tells me to turn Laughing
There are plenty of waterproof covers for phones out there that can be fitted to the bike if you need to see the maps
JAMSXR
PostPosted: 09:57 - 12 Aug 2011    Post subject: Reply with quote
I'm looking at getting one at the moment - I would be looking at something like the product in the link below to adapt my phone for my bike but as I'm due an upgrade in the next few months I'm holding out.
https://www.beshopdirect.com/ultimateaddons-pro-motorcycle-mount-kit-with-hard-wire-battery-charger-cable-and-hard-waterproof-case-for-apple-iphone-3g-3gs
The last post was made 15 years, 81 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.48 - MySQL Queries: 13 - Page Size: 133.29 Kb
