replacing the indicators, splce or do It properly?
Vexon101
PostPosted: 02:24 - 11 Aug 2011    Post subject: replacing the indicators, splce or do It properly? Reply with quote
Buying a new pair of indicators tomorrow since one of mine is broken, I've never done It before so I'm not sure If I should just splice It instead of attaching the indicators properly, I've had a look and the broken indicators had been spliced so I could use that to attach It to the new indicator wires.
I've found the part where the golden metal part at the end of the indicator wire goes, but It' covered In a plastic cover which I can't get off, even If I could I would have no idea how to connect It, the mechanism works but the indicator casing Itself I completely broken so I decided to replace them completely.
So If you could give me some instructions that would be great.
PostPosted: 12:41 - 11 Aug 2011    Post subject: Reply with quote
If you can solder the best solution is to cut the original wires where they are soldered to the bulb holders then pull them out through the body. THen when you receive the new indicators simply solder your old wires in place of the new ones by the same proceedure.
If you can't solder, or if the wires are moulded into the body of the indicators, the next best thing is to cut the old wires off about 2" from the indicator body on both old and new ones then solder/crimp the old wires onto the new ones & insulate with heat-shrink. Stagger the joints by an inch if you have to pull them through any tight holes.
Vexon101
PostPosted: 15:41 - 11 Aug 2011    Post subject: Reply with quote
Just got a pair of indicators from halford's & attached them outside the store, I basically just spliced the original wires & attached them to the new ones by twisting them together and wrapping In electric tape.
PostPosted: 15:46 - 11 Aug 2011    Post subject: Reply with quote
Stinkwheel is going to punch you in the face.
Vexon101
PostPosted: 16:11 - 11 Aug 2011    Post subject: Reply with quote
Stinkwheel is going to punch you in the face.[/quote]
Lol, I know It was an amateur/short term solution but that was how the original indicator was done by a previous mechanic, I guess when I get the spare cash I can get some decent looking ones and have them installed properly, halford's indicators don't look very nice.
PostPosted: 16:40 - 11 Aug 2011    Post subject: Reply with quote
No mechanic would join wires like that, I wouldn't let a "mechanic" who did that even look at my bike from a distance.
Buy yourself a set of crimps and some self amalgamating tape, with will cost you £15-20 and you will likely serve all your wiring need for the next 10 years. Thumbs Up
pits
PostPosted: 16:54 - 11 Aug 2011    Post subject: Reply with quote
Remember if you solder them on, it makes it an arse to take the fairings off, should you ever need to, get some decent insulated connectors and do it properly, there is very few times and even fewer places twisting wires and taping should ever happen.
Frost
PostPosted: 17:33 - 11 Aug 2011    Post subject: Reply with quote
Nothing wrong with a tape joint as a quick fix to get you home. But while in halfords you should have bought a cheap soldering iron, solder, heat shrink, wire strippers and perhaps some bullet connectors.
Bullet connectors are useful to have on indicators so that you can unplug them when you take the fairings off. If your bike is a naked just strip the ends of the wires, push a length of heat shrink down one wire, hook them both onto each other, wrap the wire round and solder. Then slide the heat shrink over the joint and heat it up. Strong & Water proof.
The last post was made 15 years, 27 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.44 - MySQL Queries: 13 - Page Size: 64.96 Kb
