Ignition Spark Plug Tester Readings
WannaBeDude
PostPosted: 12:37 - 12 Aug 2011    Post subject: Ignition Spark Plug Tester Readings Reply with quote
How do you make sense of any readings when using one of these ? Karma
paddlesat16
PostPosted: 12:40 - 12 Aug 2011    Post subject: Reply with quote
It just lights up i.e showing the spark, that way you know if you've got a spark Very Happy
I once saw a bloke shagging a donkey.... in Saudi arabia. Theory Test Passed 26/10/09 Mod 1 Passed 26/4/10, Mod 2 Passed 7/6/10 Current Bikes Suzuki GSX1400 K5, Aprillia Pegaso 650, Suzuki DR350T.
WannaBeDude
PostPosted: 12:48 - 12 Aug 2011    Post subject: Reply with quote
What if it flickers at a rapid speed etc ? Confused Thumbs Up
SoND
PostPosted: 12:56 - 12 Aug 2011    Post subject: Reply with quote
Derp, take a guess.
temeluchus
PostPosted: 13:10 - 12 Aug 2011    Post subject: Reply with quote
Is covdude real?
WannaBeDude
PostPosted: 13:24 - 12 Aug 2011    Post subject: Reply with quote
I don't know if it should glow only or flicker, wether i need to see a consistent of either. It's a silverline tester with no instructions.
at106
PostPosted: 13:28 - 12 Aug 2011    Post subject: Reply with quote
Do you have a working bike or car which you can test it on?
Raffles
PostPosted: 13:53 - 12 Aug 2011    Post subject: Reply with quote
I was told that the best way to use one of these testers is to employ an additional wire with one end connected to the uninsulated part that goes into the plug cap and the other end connected to your knackers. I'm not sure whether or not this information is correct but you could maybe give it a try.
WannaBeDude
PostPosted: 13:59 - 12 Aug 2011    Post subject: Reply with quote
Think i'll give the workshop a miss, back to cuntdude in random / gen bike chat. Rolling Eyes Smile
PostPosted: 15:20 - 12 Aug 2011    Post subject: Reply with quote
your spark is on off on off on off... so the tester should be the same..
WannaBeDude
PostPosted: 15:57 - 12 Aug 2011    Post subject: Reply with quote
Caus if i test the spark on the cylinder head, i will blow the bike up Cool
You have some suggestions for cdi testing, or are you talking about cdis that you can plug into to diagnose.
The last post was made 15 years, 26 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.27 - MySQL Queries: 13 - Page Size: 70.66 Kb
