CB-1 on the blink!
SpannerMonkey
PostPosted: 18:16 - 13 Aug 2011    Post subject: CB-1 on the blink! Reply with quote
Okay, so long story short, let a lad ride my bike, didnt have correct insurance, got pulled, impounded, he gave me the money to collect it... I collected it, on the way back the bike had NO power above 5k revs, just spluttered, would rev in neutral but hesitates at 6k for a split second. barely manages 70mph...
THEN I noticed I had no indicators that worked... or a neutral light... and my temp gauge wasnt working... Hang on a minute? I've lost all electrics bar the starter, ignition and headlight... everything else has gone...
the impound believes they did no damage to the bike... any ideas guys?
My bike? A YX140 powered one-off Monkey Bike, something a little different!
Mikey CB500
PostPosted: 18:28 - 13 Aug 2011    Post subject: Reply with quote
Checked all of the fuses? i belive the cb400 to be the same as the cbr400 and if the rev counter wiring block is lose it sends a message to the cdi as reduces the max rpm some how, may be worth a shot as i know my cbr400 wouldnt rev right without the rev counter fitted but once plugged back in it solved the problem, even tested this out on a ride once
also did your buddy do anything to the bike when he got pulled or abandoned it?
SpannerMonkey
PostPosted: 18:47 - 13 Aug 2011    Post subject: Reply with quote
nope, copper waited by the bike and had it loaded onto a bike trailer thing.
Havent checked fuses yet... rev counter seems to be fine... it just splutters past 5krpm... almost like its misfiring. runs sweet till 5k
Mikey CB500
PostPosted: 18:49 - 13 Aug 2011    Post subject: Reply with quote
Thats exactly what my cbr did with the rev counter unplugged so it could possibly be a lose wire behind your clocks? As when the rev counter was plugged in was fine
MickC
PostPosted: 18:53 - 13 Aug 2011    Post subject: Reply with quote
Ask your 'mate' how it was running before he got pulled, did he try to do a runner on it? Might of been over reved etc if he did.
Might be good idea to check the charging system, make sure you are getting a14.4 volts across the battery at 3000rpm. As 'Mikey CB500' said check all the fuses. Also any connector blocks. If the bike is fitted with an alarm make sure that hasn't been damaged or tampered with.
XX XXXx
Previous: CG125,XS250 (converted to 400),Z250A, GPZ550, Norton Commando, XS500, 78 Laverda Jota, GPZ1100,Harris bonneville, XV750 (mono shock),TR1
cb1rocket
PostPosted: 18:57 - 13 Aug 2011    Post subject: Reply with quote
the -1 requires the clocks to be connected, esp the speedo, otherwise the limiter kicks in and limits power to 5k rpm - its a jap restriction thing.
Mikey CB500
PostPosted: 19:01 - 13 Aug 2011    Post subject: Reply with quote
cheers for confirming that buddy thought it was the same as the cbr400rr nc29 jap imports Thumbs Up , there semi electrical clocks and iff you unplug them it makes it missfire, first time i took the front end off my bike and tried running it i thought id dropped a coil or the cdi had gone lol
so yeah could certainly be a lose wire by the sounds of things buddy
SpannerMonkey
PostPosted: 19:04 - 13 Aug 2011    Post subject: Reply with quote
Woohoo! Will have a check when I get back then methinks Very Happy
cb1rocket
PostPosted: 19:11 - 13 Aug 2011    Post subject: Reply with quote
or just plug a live +12v feed into the wire and run no clocks and have full power and the limiter bypassed.
SpannerMonkey
PostPosted: 19:25 - 13 Aug 2011    Post subject: Reply with quote
I like having clocks thankyou... I need to fix it up before I can sell it Razz
cb1rocket
PostPosted: 20:20 - 13 Aug 2011    Post subject: Reply with quote
selling so soon? There great bikes Surprised
SpannerMonkey
PostPosted: 20:32 - 13 Aug 2011    Post subject: Reply with quote
Not disputing that, but it's not exactly fuel efficient. And realistically, it's excessive for what I need. I only really do town runs.... and I'm not afraid of riding 100 mile on a 50... Lets face it, I rode to oxford on the PC50 which is bang on 100 miles.
ThoughtContro...
PostPosted: 21:27 - 13 Aug 2011    Post subject: Reply with quote
That's all down to how you ride it. The mad screaminess of the CBR400 engine will encourage hooligan acceleration which is not good for fuel economy.
There was an old guy who posted on 400greybike who said he'd changed the sprockets and was pottering around at a fairly sedate 50mph, which I presume he didn't scream up to in, ooooh half a second or so Razz , and he was claiming 70mpg.
That's as good as any old 250 you'll replace the bike with. You could go back to a 'runs on fumes' 125 but there'll be times when you wished for more power, especially on NSLs and motorways.
125s are a great town bike, but totally gutless once things open up. That might be fine if you're not in a rush, but when the road is a high speed battleground the extra power helps.
Prize cunt
cb1rocket
PostPosted: 21:35 - 13 Aug 2011    Post subject: Reply with quote
mine was good for 60+ mpg on my runs, and always above 50 round town. Yes its all down to how you ride it.
The last post was made 15 years, 44 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.23 Sec - Server Load: 3.48 - MySQL Queries: 13 - Page Size: 85.06 Kb
