| apple tango |
 apple tango Crazy Courier
| Frost |
 Frost World Chat Champion
| Howling TerrorOutOfOffice |
 Howling TerrorOutOfOffice Super Spammer
| apple tango |
| Irezumi aka Reuben |
 Irezumi aka Reuben Carrot Top
| Frost |
| RPM |
 RPM Nova Slayer
 Posted: 19:30 - 14 Aug 2011 Post subject: |
Hi there
On the main part of the derailleur you should find two screws beside each other
If the gears slip/shift down a gear (towards the wheel) adjust the screw to align the derailleur slightly outwards from the bike.
If it slips/shifts up a gear then adjust the other screw carefully to move it slightly inwards. Be careful not to over adjust, this can cause the chain to be thrown over the top of the largest rear cog (ouch!!)
The screws should be marked with arrows or similar.
If you do this and there is no difference then check the overall chain length. If you remove any more links just make sure that the chain is long enough to fit onto the largest front and rear cogs (sprockets). Yes.... I have previously made this mistake
Mike |
| apple tango |
| Dazbo666 |
 Dazbo666 World Chat Champion
| RPM |
 RPM Nova Slayer
| stinkwheel |
 Posted: 14:40 - 15 Aug 2011 Post subject: |
ITT, a fair bit of inaccuracy and half truths.
There are two screws underneath the derralieur. They are simple stops for top and bottom.
Set the indexing first by putting it on the middle ring on the front and one of the middle rings at the back. Set the position of the indexing using the large adjuster arrowed on Frosts diagram. The jockey wheel on the deralieur should be lined up exactly with the sprocket you're on so twiddle it until it is. When it's set right, turning the wheel using the pedal should have nearly no chain noise.
Once the indexing is set, use the other two screws (which are simply an upper and lower limit screw) to stop it shifting off the top or bottom of the casette while in the relevant gear.
All of that said, it all looks suspiciously clean and shiny. TOO shiny. I'd be very tempted to whip the chain off and check how loose it is. If you can hold it horizontally at waist height and the other end touches the floor, it's fucked. Or simply check how much sideways play there is (should be minimal).
Sprockets take a LOT of wearng out and it would usually be the smallest that goes first. 11 tooth sprockets are notorious for skipping but you don't have one. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| UnknownStuntm... |
 UnknownStuntm... World Chat Champion
| apple tango |
| colin1 |
 colin1 Captain Safety
| JonB |
 JonB Afraid of Mileage
The last post was made 15 years, 45 days ago. Instead of replying here, would creating a new thread be more useful? |
