suzuki gz125 black oil window
gypsypunk
PostPosted: 17:56 - 14 Aug 2011    Post subject: suzuki gz125 black oil window Reply with quote
my problem is i have black oil window been meaning to do a oil change but want to sort the clogged oil window
my bike is a suzuki gz125 w reg bought it like that months ago runs fine just a dirty window
pepperami
PostPosted: 18:04 - 14 Aug 2011    Post subject: Reply with quote
Have you tried going to a motor-factors shop and buying some kind of oil additive that cleans your engine on the inside as you run it?
Robby
Dirty Old Man
PostPosted: 19:18 - 14 Aug 2011    Post subject: Reply with quote
A few miles on clean oil should sort it. I would keep away from engine flushes and the like.
The window will be black if the oil is ancient, new oil might clean it. If it doesn't, then take off the side casing and clean it with a solvent.
The oil change interval will be about 2000 miles on that engine BTW, so if you've been riding it for a few months without a service and the window was black when you got it, its probably well overdue a service.
gypsypunk
PostPosted: 19:34 - 14 Aug 2011    Post subject: yeah i will just change the oil and filter Reply with quote
ok i will just give it a change of oil and a new filter the only thing that will bother me is i will put in 950ml of oil with a new filter but wont see the oil level .. really buggin
yeah i got the bike used and been using it for a month
Fizzer Thou
PostPosted: 20:07 - 14 Aug 2011    Post subject: Reply with quote
A lady friend had her Suzuki GS125 serviced by a bike shop.On the first day back to work after having had the bike serviced she had oil dripping out of the airbox drain pipe.She took it back to the shop that had performed the service and they said that it needed a rebore as the worn piston rings were causing crankcase ventilation problems and so was causing the oil to pump up into the airbox.
When she brought it around for me for a second opinion,the first thing that we looked for was an oil level in the window.It was dark black,even after a few short miles,which showed that the oilwas doing its job.When we tilted the bike over to the left,an oil level appeared in the window.We drained off nearly 500ml of excess oil and squeezed out the air filter,which was of the foam type.
Suffice to say she was not pleased with the bike shop.
I suggest that if you drain the oil when it is hot,it will drain more thoroughly.If a clear window appears once drained,only add sufficient to go to the half way marker.Soak the filter with some fresh engine oil before installation.Run the engine for a short time to help to circulate the new oil,then top up to the prescribed level.
Always have a 'Plan B'
gypsypunk
PostPosted: 20:55 - 14 Aug 2011    Post subject: Reply with quote
yeah when you have a bike i think it's really important to be able to do service's at least on your own bike... i have spent a fortune on tools and learning all the time.. my last error was changing my brake pads the ancient dust seal shrunk onto the piston and seized an easy 5 min job turned into a call out for a mobile mechanic and and it took him an hour just to free the piston.
luckly he was really experienced ..cheap.. and a great help now i know everything about my brakes and how to bleed them would never get that from a garage or dealership.
i was thinking if i removed the crank case to clean the oil window i would probably have to replace the gasket and so would have to make shure i had one just to change the oil and filter..
just going to see how this oil/filter change goes first
gypsypunk
PostPosted: 19:33 - 15 Aug 2011    Post subject: Reply with quote
hi guys thanks for the advice i have been shocked i warmed the bike up today then leaned the bike way over on it's left and realised the window cleared .... so drained the oil and guess what the the last owner had filled it up with so much oil that it filled the window with black dirty oil . after doing a oil/filter change the little suzi is runner way better .. i cant beleve i use the bike for a month like that ... a learning curve i checked the air filter and it has taken in some oil at the bottom end so gonna change that tomorrow.
well at least i dont have to worry about cleaning the window
DrDonnyBrago
PostPosted: 08:09 - 16 Aug 2011    Post subject: Reply with quote
Did the old oil stink of petrol?
If a bike starts making it's own oil (i.e. increasing the volume) it usually means petrol is getting in, i.e. from a fuel leak in a carb leaking into the bores.
It could well just be that the moron before stuck too much oil in though Surprised .
Robby
Dirty Old Man
PostPosted: 12:11 - 16 Aug 2011    Post subject: Reply with quote
If I was doing the job, I would get the side casing off and clean the window while I'm doing the oil change. I would be doing a full service anyway.
A gasket from suzuki will leave you change from £20, or a full pattern gasket set will cost about £25, and is worth having on the shelf.
Service parts for that bike are cheap. Do the rest of a basic service while you're at it - new air filter, new spark plug, wiggle the wheels to check the bearings, wiggle the forks to check the head bearing, and have a good look at your brakes, suspension and tyres to look for leaks, holes and wear.
Don't waste money on super duper oil. A gallon of comma 10W40 will cost you a tenner and do 4 oil changes.
gypsypunk
PostPosted: 18:45 - 16 Aug 2011    Post subject: Reply with quote
the oil was just as it should be it smelt like a old ice cream van when i was a kid ...mmmmm lol
the oil window is as clean as a whistle now just orderd a air filter and brake pads/seals/fluid
what a diffrence in the performance of the bike alot more oomph
that oil change was needed badly
Mr. Green
The last post was made 14 years, 132 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.96 - MySQL Queries: 13 - Page Size: 66.72 Kb
