| bennell09 |
 bennell09 Renault 5 Driver
| bennell09 |
 Posted: 10:43 - 15 Aug 2011 Post subject: |
Leaning the engine by lowering the float height isn't a great idea on a two-stroke. Leaner mixture means more heat and too much of that means a seized engine, usually at speed. ____________________ a.k.a 'Geri'
| bennell09 |
 Posted: 11:15 - 15 Aug 2011 Post subject: |
Yes, lowering the fuel height by bending the tab up will lean the mixture across the board.
Do you have a manual for the bike so you can check what the float height should be? Usually it;s measured by tunring the carb upside-down and taking a measurement from the carb body at the float bowl sealing face to the highest point on the float, and check both sides are equal.
If it's over-flowing after setting the float height then you should look at the needle to see if it is grooved where it seals in the seat. This can be fixed by opening the hole in the seat a little so that it seals on a wider part of the needle taper and then re-setting the float height. ____________________ a.k.a 'Geri'
| bennell09 |
The last post was made 15 years, 76 days ago. Instead of replying here, would creating a new thread be more useful? |
