Bulb problem - Hyosung
emmayorkshire...
PostPosted: 12:01 - 15 Aug 2011    Post subject: Bulb problem - Hyosung Reply with quote
Hi all, I hope someone can help me out here. My bike is a Hyosung RT125 2007 model.
I changed the bulb in my bike to a Halogen upgrade one (it is the correct one as a fellow Hyosung owner recommended it) and the full beam bit blew first then the bulb fully after a couple of months. I just put a new bulb in ready for the MOT and it blew the day after (just the full beam one so far). There must be something wrong with the electrics/the switch if its doing that? If anyone could give me some advice of what to check that would be great. Also assume you are talking to a comlete novice when refering to stuff!!
Thanks
PostPosted: 12:16 - 15 Aug 2011    Post subject: Reply with quote
Put the old bulb back in and see if that blows if it doesn't the bulbs you bought where shit/not correct.
Livefast123
PostPosted: 14:45 - 15 Aug 2011    Post subject: Reply with quote
There could be a number of simple reasons
1. You are buying shite bulbs.....it is worth shelling out the extra for Phillips / Bosch etc.
2. Are you touching the glass of the bulb when you put them in. You should never touch the glass area of a halogen bulb as this greatly reduces life expetancy.
3. Is your bulb holder secure and the light unit freeish from vibration as this will kill a bulb quickly.
4. Is the wiring all insulated so that it can't create a short.
Current ride - Yamaha MT-07
emmayorkshire...
PostPosted: 07:02 - 16 Aug 2011    Post subject: Reply with quote
Thanks for your replies.
My bulb cost about £7, I would happily spend more if it is the bulb at fault and a better one will last. However I'd be reluctant to spend more if it is an electrical/mechanical fault and a £12 bulb blows after 2 days!
We didnt touch the bulb as my neighbour told me not to do that.
My break light also blows quite frequently. Last one lasted maybe 5-6 months, which could be normal for bikes for all I know Embarassed
shereen
PostPosted: 08:07 - 16 Aug 2011    Post subject: Reply with quote
Not normal lol. As someone else has said, put the old bulb back in and see if it does the same thing.
The last post was made 14 years, 138 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.56 - MySQL Queries: 13 - Page Size: 44.22 Kb
