Newb Q-Removing Old Throttle Grip
sparkywilliam...
PostPosted: 12:39 - 15 Aug 2011    Post subject: Newb Q-Removing Old Throttle Grip Reply with quote
Guys,
How do i remove my throttle grip without damaging anything?
Seems proper stuck on-i want to replace with new aftermarket ones
Thanks Guys
Previously CG125,YBR125 Now GSF600 Bandit
PostPosted: 12:58 - 15 Aug 2011    Post subject: Re: Newb Q-Removing Old Throttle Grip Reply with quote
If you didn't care about it, just cut down with a stanley knife.
As it seems you do - if you've got an airline, get a blower in there to help free it off.
Presuming not that either, try some wd40 squirted in as far as possible at either end (use the straw).
MarkJ
PostPosted: 13:02 - 15 Aug 2011    Post subject: Reply with quote
What G said. I normally get one of those long thin screwdrivers in there to make a gap, then spray brake cleaner in the gap which undoes all the glue. Might not work if the grip has been stuck on with super glue, though.
Edit: is that an Oxford heated grip? If so they have a solid inside part and you'll struggle to get anything under it. I normally crack the glue by forcibly twisting the grip the wrong way for the throttle side.
sparkywilliam...
PostPosted: 13:58 - 15 Aug 2011    Post subject: Reply with quote
yes its an Oxford Heated Grip..explain what i do in idiots language cos ive never taken one off before!
The last post was made 14 years, 166 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.04 Sec - Server Load: 0.33 - MySQL Queries: 13 - Page Size: 38.71 Kb
