suz 125 vl valve clearance
carman
PostPosted: 15:00 - 15 Aug 2011    Post subject: suz 125 vl valve clearance Reply with quote
Hi, Valve gaps need setting,it says you need to remove tank, speedo,and the need of a special tool?? Anybody know if i can set gaps without any of the above
Thanks for any info
Mick
P.
PostPosted: 15:08 - 15 Aug 2011    Post subject: Reply with quote
removing the tank is a few bolts.
Is this one of the bikes where the speedo is integrated into the tank?
If so just undo the physical cable from either the speedo or front wheel.
You just have to get the tank off and then you'll be able to get to the engine.
The last post was made 14 years, 160 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.04 Sec - Server Load: 0.26 - MySQL Queries: 13 - Page Size: 30.66 Kb
