Measuring gap/gapping iridium spark plugs
DrDonnyBrago
PostPosted: 10:27 - 16 Aug 2011    Post subject: Measuring gap/gapping iridium spark plugs Reply with quote
Morning all,
When measuring the gap on an iridium plug is it best to use a wire type spark plug gauge, a disc type spark plug gauge or a feeler gauge?
I was under the impression the feeler gauge is not suitable and one of the others can damage the tiny iridium centre electrode.
Anyone know which is the correct tool to use to measure the gap on an iridium plug?
If anyone needs to know the plug type (not sure why) they are NGK IMR9a-9h plugs.
Cheers Thumbs Up Karma .
Bezzer
PostPosted: 11:18 - 16 Aug 2011    Post subject: Reply with quote
The official manufacturers line is you don't measure or gap iridium plugs, use straight from the box and don't bother again until they are replaced. Apparently doesn't take much to scratch the coating so you pays your money and takes yer chance, I'd use a wire type gauge Mr. Green , though saying that I don't bother with Iridium plugs myself, I'd rather replace standard ones regularly than pay 2-3 times the price for Iridium.
Robby
Dirty Old Man
PostPosted: 12:19 - 16 Aug 2011    Post subject: Reply with quote
I have never seen an iridium plug wear enough to need gapping, but not need replacing. To my knowledge, the iridium coating is very hard and very thin. Once it has worn away, which takes a long time, you replace the plug. If the gap has opened up at all, the iridium coating has worn away.
I can't remember the last time I saw a spark plug worn enough to need gapping, apart from on some of my dad's garden machinery. Garden machinery spark plugs don't seem to be as tough as those used on everything else, nor are they working in such carefully controlled circumstances. I serviced the woman's car at the weekend. Changed the plugs as a matter of course, but the previous set of (standard copper NGK) plugs had done 30,000 miles and were maybe 10% worn. They would seize into the head long before wearing out.
It's a shame that plug changes are still such an ingrained service item. There are more threads in the forum about people overtightening a plug and breaking their cylinder head than about worn out spark plugs.
DrDonnyBrago
PostPosted: 12:58 - 16 Aug 2011    Post subject: Reply with quote
Appreciate the comments guys, it was more about checking the gap on the new plugs before installing them, there is a gap specified in the workshop manual and I wanted to check the new ones were set to that before using them.
Was reading this on the NGK site:
https://www.ngksparkplugs.com/techinfo/spark_plugs/installation.asp
3. Gapping
Since the gap size has a direct affect on the spark plug's tip temperature
and on the voltage necessary to ionize (light) the air/fuel mixture, careful attention is required. While it is a popular misconception that plugs are pre-gapped from the factory, the fact remains that the gap must be adjusted for the vehicle that the spark plug is intended for.
Do you guys just install them straight out the box then?
The current plugs in the bike are 21k miles old (16k intervals) and I am getting intermittent starting problems - every now and then (i.e. once every 1-2 weeks) the bike (fuel injected CBR600F) turns over about 10-15 times before it finally starts. Every other time I start the bike it starts within 1-2 cranks.
The general consensus on here seemed to be change the plugs, any other thoughts on the cause of the starting problems? Trying to nip it in the bud before I get stranded at work.
paddlesat16
PostPosted: 13:10 - 16 Aug 2011    Post subject: Reply with quote
3. Gapping
Only the irridium plugs(install straight from the box)
Standard plugs you gap Thumbs Up
I once saw a bloke shagging a donkey.... in Saudi arabia. Theory Test Passed 26/10/09 Mod 1 Passed 26/4/10, Mod 2 Passed 7/6/10 Current Bikes Suzuki GSX1400 K5, Aprillia Pegaso 650, Suzuki DR350T.
PostPosted: 17:45 - 16 Aug 2011    Post subject: Reply with quote
As an aside, anyone actually noticed any difference with Iridium plugs? I put some in a few months ago, it's made squat difference to MPG :-
Code:
Gallons   Miles   MPG
3.01   177   58.85
3.20   171   53.49
2.74   170   62.11
2.68   160   59.80   Last of the non-Iridium readings
3.07   177   57.71
3.17   180   56.81
3.27   181   55.40
3.08   180   58.48
3.23   181   56.04
3.10   181   58.30
The last post was made 14 years, 131 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.64 - MySQL Queries: 13 - Page Size: 51.86 Kb
