cuts out when put in gear
skikman
PostPosted: 11:48 - 16 Aug 2011    Post subject: cuts out when put in gear Reply with quote
hi all.i have an old kmx 125 that i striped down and painted.i have put it back together as a dirt bike so no lights ,clocks, battery ect.i started it for the first time today an it seemed fine.it was only when i put it in gear it cuts off like a kill switch.now i dont have the kill switch connected im just using the key in the barrel.do i need the kill switch connected or is there something else i forgot to connect
PostPosted: 11:57 - 16 Aug 2011    Post subject: Reply with quote
Check the side stand switch connection.
skikman
PostPosted: 12:02 - 16 Aug 2011    Post subject: Reply with quote
i never put it back on
PostPosted: 12:04 - 16 Aug 2011    Post subject: Reply with quote
There's the problem. You will need to bridge it.
DrDonnyBrago
PostPosted: 12:05 - 16 Aug 2011    Post subject: Reply with quote
In which case join the wires either end of the switch to close the circuit.
skikman
PostPosted: 12:47 - 16 Aug 2011    Post subject: Reply with quote
In which case join the wires either end of the switch to close the circuit.[/quote] i broke it taking it off.can i just pust the connectors together and cut the wires going to the switch and join them together
PostPosted: 12:48 - 16 Aug 2011    Post subject: Reply with quote
i broke it taking it off.can i just pust the connectors together and cut the wires going to the switch and join them together[/quote]
Yes.
skikman
PostPosted: 14:31 - 16 Aug 2011    Post subject: Reply with quote
Yes.[/quote] i did that and it didnt work.then i noticed wires coming from the clutch lever.i cut and joined these wires and away i went.hope this helps someone in the future.thanks for the help folks.
The last post was made 14 years, 137 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.48 - MySQL Queries: 13 - Page Size: 57.36 Kb
