PIston ring interchangability
kneedown
PostPosted: 18:55 - 16 Aug 2011    Post subject: PIston ring interchangability Reply with quote
Piston ring interchangabiity
Hi peeps
Wanted to know if you can use any piston rings on a piston if they are the same bore diameter have a set of gsxr 750 72mm rings was going to use on my yzf 750 any thoughts?
kneedown
PostPosted: 20:39 - 16 Aug 2011    Post subject: Reply with quote
Out of intrest why would stroke affect piston rings if the yzf750 pistons are being used
PostPosted: 20:43 - 16 Aug 2011    Post subject: Reply with quote
Several different designs of rings.
There are L shaped rings, rings with a tapered profile, etc.
Also other dimensions vary, sometimes even on the same model (Rotax / Aprilia changed the thickness of the rings on the RS125 engine in the 1990s).
The last post was made 14 years, 138 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.17 - MySQL Queries: 13 - Page Size: 45.28 Kb
