Bike Alarm Phone Call.
PostPosted: 22:15 - 16 Aug 2011    Post subject: Bike Alarm Phone Call. Reply with quote
Mrs Pinky found this on another site and I thought it might be worth posting here. Sorry if its a pea roast but I couldnt find it in the search.
Alarm Phone - a set on Flickr
Basically all you need to do is replace the green key on a standard (non-touch screen) phone with a "trembler" switch.
The switch you need can be found here Assemtech | Process Control | Sensors and Transducers | Nonmercury Tilt Switches | Non-Mercury Tilt, Vibration & Movement |S1425
Just connect this across the tracks on the PCB. On standard mobiles, if you press the green key twice it dials the last number dialled.
So what you do is put the number of your mobile in and call it (by shaking the phone). In your mobile you create a contact called "Bike Alarm" and enter the number of the alarm phone.
I recommend getting a new PAYG SIM for the alarm phone.
To use the alarm, turn it on and hide it on the bike. If anybody messes with it, the alarm will phone you up, so you get a phone call from "Bike Alarm". At that point you can either grab your Machete and run, or answer the call and have a listen, or do whatever you feel.
It's best to answer the call and hang up immediately, because you have to pay for whatever the alarm phone does, so if it calls your mobile and you don't answer it'll go to voicemail for 2 or 3 minutes before your phone hangs up.
If you want to test if the alarm phone is in network and working you can call it up. If you here the ringing tone your set. Of course you need to set the ring tone on the alarm phone to silent.
Looks like a decent contraption and with vandalism to 3 bikes in the last 2 years I might be rigging one up myself.
Germ
PostPosted: 22:51 - 16 Aug 2011    Post subject: Reply with quote
Get the phone to dial 999 maybe?
If my experiences with watching CSI:Miami have taught me anything it's that you can expect Horatio Caine to look all wistful and then use the Mobile phone transmitters to triangulate your phone,ergo your bike Wink
Paulington
PostPosted: 05:37 - 17 Aug 2011    Post subject: Reply with quote
If you have a bit of cash spare then this is basically what Bike Trac does. It can text/e-mail/ring you if your bike is moved without the alarm off.
At any time you can log on their website and see the location of your motorcycle plus 'breadcrumb' style journeys overlayed Microsoft Virtual Earth to show where your motorcycle HAS been. If it gets nicked then Road Angel gives all this info to the Police so they don't even have to use the tracker hardware with the Police car, Road Angel can tell them exactly where it is.
To be honest with you I'd rather spend naff all on disc locks/massive chains/loud alarms/immobilisers etc and just spend money on a semi-decent chain and the Bike Trac, it's fantastic.
Marmalade
PostPosted: 06:21 - 17 Aug 2011    Post subject: Reply with quote
On my alarm it has relay outputs, constant when on and momentary when turning on or off. Could use these on something like a nokia 3310 and wire it to turn phone on and off with alarm. coupled with this movement switch it could work quite well.
I've a few old boards here so might have a play.
PostPosted: 07:24 - 17 Aug 2011    Post subject: Reply with quote
Paul. While I do agree with the chains and alarms approach what would you recomend for me? I have a loud alarm, I also have a disc lock and a whacking great big chain.
But, I have to park my bike around 50 meters away from where I live and my the time I get into the 1960's concrete walled flat any sound from the alarm is lost. I've had alarmed bikes vandalised 3 times in 2 years.
waffles
PostPosted: 09:59 - 17 Aug 2011    Post subject: Reply with quote
I have Bike Trac and in my experience it is very sensitive! If I roll the bike out of the garage without putting the key in the ignition (a couple of meters max), I get a text to tell me my bike has been moved. My friend helpfully wheeled my bike off of a busy petrol station forecourt into a parking space and I got a text and a phonecall within a minute of it being moved. Same thing when the bike had some work done in a garage and the didn't put the key in.
I will check to see if I get an alert by pushing my bike or sitting on it, I'm pretty sure it will. Yes, it's pretty expensive to initially set up but it will alert you if someone is screwing around on your bike.
If you do go with the mobile phone idea make sure you hook up a charger for it and disable it when you go for a ride!
PostPosted: 11:18 - 17 Aug 2011    Post subject: Re: Bike Alarm Phone Call. Reply with quote
Sounds shit, sure everytime you move the phone or bike it will call you. Pain in the arse. Laughing
UnknownStuntm...
PostPosted: 11:20 - 17 Aug 2011    Post subject: Reply with quote
Surely it would need to be 911 then.
c-m
PostPosted: 13:18 - 17 Aug 2011    Post subject: Reply with quote
Better to just plug a phone into your bike with gps, and put a data only sim in it. Then install tracking software.
I've got an old android phone, but if my bike gets stolen, i'd rather the insurance money to get a new one Very Happy
Motorcycle headlight bulbs and HIDs
Blogging about my bike and trips
https://ridershandbook.com/
Oldie
PostPosted: 20:18 - 17 Aug 2011    Post subject: Reply with quote
Snooper (SPT 200) do a cheapo system which I've used before on a caravan which I kept at a remote address. Costs about £100 and you put any old sim into it. Then set the distance the bike can be moved before the unit sends you a text. Really simple and effective. The text links straight to google maps on your phone or you can check it on your computer.
However, for best results, it needs to be hard wired to your battery as the inbuilt battery only lasts about 3 days, from memory.
I did have a couple of false alarms which I put down to the signal being lost (don't use O2) but otherwise it was great. If your bike gets nicked, you get a text saying that it's been moved and after that all you do is call up the Snooper and it tells you it's current location. Mine was accurate to a couple of metres.
Edit - there are no other charges once you have purchased the unit, apart from the cost of the texts.
The thing to do is get a sim which is text only (say 5p per text) as you'll end up playing with it Very Happy
The last post was made 14 years, 142 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.33 - MySQL Queries: 13 - Page Size: 74.09 Kb
