Help, Stuck at 6000 rpm
adamcfc
PostPosted: 10:01 - 17 Aug 2011    Post subject: Help, Stuck at 6000 rpm Reply with quote
Hi all, was out riding with my friend last night when we turned a corner and his bike has started playing up. Any ideas or help would be great.
We were coming off a duel carriageway round a tight left hand bend, as he straightened up he felt he was in too high a gear as the bike was bogging and he changed down to 1st, then as he began to accelerate the bike got to 6K rpm and wouldnt go any higher, its spluttering and doing about 5mph.
The bike is a Derbi GPR 50, since hes had it we know its been running rich, but he hasnt bothered to sort it out as it isnt appearing to cause him any immediate problem at the moment.
I have an idea that maybe some crud has found its way into the carburetta and blocked the main jet, would this cause fuel starvation at 6000 rpm? I also read somewhere that a pipe (something to do with an air pipe) coudl have come off the carb?
Many Thanks, Adam
PostPosted: 10:05 - 17 Aug 2011    Post subject: Reply with quote
I'd change the plug first.
If it's a 2-stroke and it's been running rich, the plug is probably heavily fouled with carbon.
adamcfc
PostPosted: 10:32 - 17 Aug 2011    Post subject: Reply with quote
How could it suddenly of stopped working round a corner though?
And il order a new plug Smile
Snorty
PostPosted: 11:13 - 17 Aug 2011    Post subject: Reply with quote
He didn't leave the choke on or anything did he? I did that by accident on my 125... cyclists were overtaking me uphill lol.
Sounds likely to be the plug, straw that broke the camel's back so to speak.
adamcfc
PostPosted: 13:47 - 17 Aug 2011    Post subject: Reply with quote
No its not the choke, it happened when he was riding and the choke wasn't on. I'll check the plug in the next day or so, but no one thinks a jet blockage?
PostPosted: 14:14 - 17 Aug 2011    Post subject: Reply with quote
Could be but 9 out of 10 carb problems are electrical.
If a 2-stroke is running oddly, the first thing to do is change the plug.
Teflon-Mike
tl;dr
PostPosted: 20:39 - 17 Aug 2011    Post subject: Reply with quote
OK, I think it may be a jet blockage.....
NOW go check the fucking spark plug!
Don't matter whether its a two stroke, four stroke, car, bike, or a moped....
IF you have an engine fault, and the engine has a spark plug... YOU CHECK IT... regardless.
Its like the first thing you do!
WHETHER the plug is fouled or fucked dont matter... bike was running, the spark plug tells you HOW it was running.
If ritch, it will be black and sooty, if lean, white, if overheating, it'll have deposits on it. There'll be a whole page in the manual with photos of spark plugs fort you to compare to, telling you what each picture means.
WHATEVER is wrong, spark plug gives clues....
And guess what?
Its a two stroke...... I'll lay odds its nothing more than the plugs fucked!
If you don't know that's the first thing to check, probably don't know they also need new ones quite frequently... whether fouled or not!
adamcfc
PostPosted: 20:57 - 17 Aug 2011    Post subject: Reply with quote
Ok cheers Stinkwheel.
And thanks for your help too Mike, but calm down? I know the first thing to do is to check the plug, and i know the electrode can diagnose many problems ..... BUT
I cant go and 'fucking check the spark plug' becuase its my freinds bike at his house. Im seeing him tomorow, which is why i wish to have a 'checklist' of things to try with it. Rest assured number one will be checking and probably replacing the spark plug.
If that doesnt help then next i will check the air filter, and fuel lines, check no pipes have come off the carb, and finally strip the carb and clean the jets.
Does this sound logical?
Adam
PostPosted: 20:59 - 17 Aug 2011    Post subject: Reply with quote
Seems like a plan of action to me.
The last post was made 14 years, 141 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.03 - MySQL Queries: 13 - Page Size: 63.76 Kb
