| Hallsy |
 Hallsy Derestricted Danger
| angryjonny |
 angryjonny World Chat Champion
| Richy92 |
 Richy92 L Plate Warrior
 Posted: 17:24 - 17 Aug 2011 Post subject: |
I did the theory about a month ago, try to keep it to a max of ten clicks per clip that worked for me. I actually did 12 on one of them which was fine, I think the limit is 14 per clip.
If you dig around the net there is a great DSA test CD available, I used it, had 1200 questions and 72 clips to help you prepare.
good luck  |
| Turks |
 Turks Nova Slayer
 Posted: 17:32 - 17 Aug 2011 Post subject: |
It helps to click, wait one second, then click again at very hazardous situations. If you click in quick succession the clip gets disqualified.
When I did mine, there were two young cyclists on each side of the road, so theres me clicking like crazy... the clip got disqualified. Instantly losing an entire 5 points makes the rest of the test a lot harder to pass. Never-the-less I passed first time  |
| angryjonny |
| Hallsy |
| Germ |
 Germ Trackday Trickster
| Hallsy |
 Posted: 14:04 - 18 Aug 2011 Post subject: |
Passed
48/50 on the multiple choice, and 54/75 on Hazard Perception.
Not as good as I'd hoped on HP, but after quite a few practice goes I found myself seeing the hazards a little early and worrying about clicking too early, so clicking again to make sure.
Trouble is I had one clip where the hazard was so obvious, but seemed slow to delveop - yep, clicked too many times, zero!! Never did it in my practice ones, nevermind, still managed to get enough 4's and 5's to get through!
Now to book up my DAS  |
| Germ |
| Hallsy |
 Posted: 14:32 - 18 Aug 2011 Post subject: |
It's fairly obvious usually, the trouble is, if you're already an experienced driver you will see all sorts of potential hazards, the ones where you cover a brake pedal, or come off the throttle, etc.
It's OK to click everything you think is a possible hazard, as long as you don't click too many times!! For me, you seemed to be able to get away with the odd click where nothing happened, and up to 4 clicks when something did happen. Problem comes if you click to quickly, or rapid fire everywhere!
Basically you are looking for clues like pedestrians, parked cars, sudden braking, people cutting across, etc. Trouble comes with clicking when the DSA think you should.
Sometimes the hazard will happen very quickly and to get full points you needed to click almost as soon as you see the vehicle that causes the hazrad, yet on others it may be a slow moving hazard that you can see happening a mile off, but the DSA only want you to respond as it causes a hazard.
The one I got penalised on for clicking too many times was a DC stretch with a HGV parked in a rest spot, as soon as it started to move I knew it would be a hazrd so I clicked, and clikced three timed about 0.5 sec apart as I had been doing, but then it stopped, then it started to move again and pulled out, as you're concious you may have been too early I probably clicked a couple of times when it stopped, then again when it pulled out. Too many clicks in too short a time frame.
Still, as long as you are getting mostly 4's and 5's you can afford to make a few mistakes. I found this DVD very good practice - Driving Test Success Hazard Perception Test. I got mine from ebay for about £7 posted.
Practiced for a couple of hours yesterday and felt fairly confident today. Apparently the DSA HP one is pretty poor. |
| Jamey |
 Jamey Trackday Trickster
The last post was made 15 years, 76 days ago. Instead of replying here, would creating a new thread be more useful? |
