gz125 speedo went crazy random now gives no reading
gypsypunk
PostPosted: 18:03 - 17 Aug 2011    Post subject: gz125 speedo went crazy random now gives no reading Reply with quote
my speedo went wonky randow crazy reading then calmed down gave a wobbly reading then now i get nothing ... so far i have cleaned all the crud out the cable and set it back up but still no reading ........whats the chances of it being the speedo clock (there is still power going thru it) or the speedo drive
your help will be appreciated
Teflon-Mike
tl;dr
PostPosted: 20:28 - 17 Aug 2011    Post subject: Re: gz125 speedo went crazy random now gives no reading Reply with quote
How have you cleaned the crud out of the cable?
Have you pulled the inner cable and checked its not snapped in the middle, and then greased?
Symptoms SOUND like simple case of snapped cable to me.
Speedo goes 'crazy' as the wire starts to break up & it twists and unwinds... then gives up altogether when it finally snaps.
gypsypunk
PostPosted: 21:17 - 17 Aug 2011    Post subject: Reply with quote
i removed the speedo cable and inner cable and cleaned both it's not snapped i had it out and blasted it with wd40 cleaned it off and lightly LM greased it.
still no movement in the dial when i rode it dummer i got a rear paddock but not a front one could have checked to see it the cable is turning it does by hand but on a stand i would see if the speedometer gearbox was doing it's job. then i would be one step forward. will have a look over it tommorow
Teflon-Mike
tl;dr
PostPosted: 21:53 - 17 Aug 2011    Post subject: Reply with quote
Is the end rounded off? If it was fretting in the drive, then they can loose thier corners and 'jump' until they completely round off, similar symptoms.
gypsypunk
PostPosted: 22:20 - 17 Aug 2011    Post subject: Reply with quote
it did look a bit rounded but not spear like but not square edges it does look like this so doubt it is the cable https://www.wemoto.com/bikes/Suzuki/GZ_125_W_X_Y_Marauder/98-00/picture/Speedo_Cable/
Teflon-Mike
tl;dr
PostPosted: 22:27 - 17 Aug 2011    Post subject: Reply with quote
Symptoms suggest cable. And 9/10 times speedo faults are the cable. I'd not be so quick to dismiss it.
Try finding something you can drive the speedo with off an electric drill.... I'll bet it works, and its the cable slipping.
The last post was made 14 years, 153 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.86 - MySQL Queries: 13 - Page Size: 54.06 Kb
