head skimming
bombom
PostPosted: 20:35 - 18 Aug 2011    Post subject: head skimming Reply with quote
Now i know that with a car when removing the cylinder head you get it skimmed, its it the same story with a bike?
bike is a gsf400.
cheers
Current: 97 zx6r f3
Previous: suzuki gsf400 bandit
jimspeed
PostPosted: 21:00 - 18 Aug 2011    Post subject: Reply with quote
It depends on the reason for removing the head really, if its been overheating or had a blown headgasket then yes but if you are just stripping it to do the valves or rings etc then I wouldn't as it can effect the valve timing and compression ratio ideally you want to remove as little as possible from it to ensure it is flat.
Hyosung cruise 125(passed test on, sold) Kawasaki el 252 (better than expected but sold on) Kawasaki GPZ500S first "big"bike.(sold) ZZR600 E5..Z750 2007,ER5, currently on a 2008 Enfield bullet electra x and loving it..
,"Alpha-9: Is there any correlation between dyno rod and dyno kits?"
MickC
PostPosted: 21:03 - 18 Aug 2011    Post subject: Reply with quote
As Jimspeed said if there hasn't been a problem leave it alone but don't forget to get it a good quality replacement head gasket.
XX XXXx
Previous: CG125,XS250 (converted to 400),Z250A, GPZ550, Norton Commando, XS500, 78 Laverda Jota, GPZ1100,Harris bonneville, XV750 (mono shock),TR1
Paddy Blake
PostPosted: 22:21 - 18 Aug 2011    Post subject: Reply with quote
I never did this but have read of people using grinding past on glass for slightly warped heads but I would not get it skimmed because the valves might hit the pistons and you engine is the wrecked.
1 Thousand of an inch on a bike engine is a lot compared to most cars.
0l0dom0l0
PostPosted: 22:53 - 18 Aug 2011    Post subject: Reply with quote
I had both the head and the barrels skimmed when I did the engine on the Fazer.
Total of 7 thou removed, god knows what compression ratio the thing was running. Always used decent fuel and it went like shit off a shovel!
You won't start mashing valves into pistons dw. I'd get the head skimmed after every time it was removed.
bombom
PostPosted: 18:36 - 19 Aug 2011    Post subject: Reply with quote
im just going to be doing the valve stem oil seals as its using quite abit of oil.
my problem with getting it skimmed is finding where can do it as my local engineers said it would be too small to fit there machine.
suppose il have a ring round closer the time and get some prices
cheers chaps
Current: 97 zx6r f3
The last post was made 14 years, 176 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.54 - MySQL Queries: 13 - Page Size: 52.6 Kb
