| alan0259 |
 alan0259 Nova Slayer
 Posted: 12:24 - 23 Aug 2011 Post subject: Took rear wheel off, should this part have play in it? |
As above really, took the rear wheel off to get a new tyre put on and noticed a bit of play behind the sprocket...
Now I've bolted it back to the bike it doesn't move at all...
Bike is a 1998 CBR 600 F3...
Click the pic below to view video
https://i890.photobucket.com/albums/ac107/alan0259/CBR/th_IMG_0532.jpg |
| P.addy |
 P.addy Red Rocket
| Wafer_Thin_Ham |
 Wafer_Thin_Ham Super Spammer
 Posted: 12:30 - 23 Aug 2011 Post subject: |
Worn cush drive rubbers I suspect if there's loads of play, but there would be other symptoms (like abnormally clunky drive when opening the throttle).
The sprocket carrier isn't really attached to the wheel, it sits in there with the cushdrive rubbers and it's a tight enough fit to keep it in there when the wheel's out.
If you wiggle it you should be able to slide the carrier out and check the cush drive rubbers, be aware some will fall out when you do this. If all is well simply replace. If they are massively worn you can either replace the cush drive rubbers or bodge it using stripes of bicycle inner tube cut up and slotted in (although I wouldn't advise it). That said I've never needed to replace a sprocket carrier or cush drive rubbers on any of my bikes.
Short version - It's fine provided the play's not excessive. ____________________ My Flickr |
| whitedevil |
 whitedevil World Chat Champion
| Pete. |
 Pete. Super Spammer
| alan0259 |
The last post was made 15 years, 52 days ago. Instead of replying here, would creating a new thread be more useful? |
