| DrDonnyBrago |
 DrDonnyBrago World Chat Champion
 Posted: 16:21 - 29 Jul 2011 Post subject: Bike occasionally hard to start - update |
Afternoon,
My bike (Honda CBR 600f 2001 - FI model not carb'd) was a bitch to start this afternoon. Turned over about 15 times before it caught and fired up.
It has done this a few times (although never this bad, at worst 5/6 turns before starting) and every time has been in the afternoon about 5 hours after parking up, never has an issue in the morning.
Electric starter sounded strong, heard the fuel pump prime before I started it and after a while I gave it a bit of throttle whilst cranking which didn't seem to help. Could smell fuel in the air after it finally started.
What should I check? Throttle bodies haven't been balanced and the valve clearances are a few k overdue, money is tight atm and the spark plugs are iridium jobbies getting on for 20k now so 4k older than the service schedule recommends - any of this (or all of this) likely to be the issue? I have a multimeter, can I check that the battery is still half decent as opposed to just charged up? Any thoughts as to why it only happens when the bike is still a bit lukewarm (is ALWAYS fine when stone cold or quite hot)?
Thanks chums .
| P.addy |
 P.addy Red Rocket
 Posted: 16:28 - 29 Jul 2011 Post subject: |
Mines ok from cold, but if i say leave it 15 mins and the engine is still warm and go to start it does seem to want a bit more of a crank I'd like to hear if anyone has a resolution to yours... Im thinking my plugs are getting changed asap.. but looks a bitch on that bike  |
| Vincent |
 Vincent Banned
| chris-red |
 Posted: 17:08 - 29 Jul 2011 Post subject: |
Plugs first, then carbs then valves.
A good service should sort it.  ____________________ Well, you know what they say. If you want to save the world, you have to push a few old ladies down the stairs.
WANTED:- Fujinon (Fuji) M42 (Screw on) lenses, let me know if you have anything. |
| DrDonnyBrago |
| DrDonnyBrago |
| hmmmnz |
 hmmmnz Super Spammer
 Posted: 09:33 - 23 Aug 2011 Post subject: |
despite hondas sterling reputation,
they do quite often eat cams,
i'd be having a look at the valve clearances and cams,
its an annoying job but one well worth doing,
being the bucket over shim system, the cams will have to come out anyway to change those pesky shims, check the cam run out, wear on the cams,
and most importantly the oil jets that they are not blocked,
my money is on a valve related issue ____________________ the humans are dead
I kick arse for the lord
Wiring Diagrams BIDNIP it bitches |
| DrDonnyBrago |
 Posted: 10:29 - 23 Aug 2011 Post subject: |
| hmmmnz wrote: | despite hondas sterling reputation,
my money is on a valve related issue |
Cheers, will have a proper look when I do the clearances, farking hope it isn't though, can't be doing with needing a new head! |
| satelliteone |
 satelliteone Nitrous Nuisance
| DrDonnyBrago |
| Robby |
 Robby Dirty Old Man
| satelliteone |
| P.addy |
 P.addy Red Rocket
The last post was made 15 years, 45 days ago. Instead of replying here, would creating a new thread be more useful? |
