Chain and Sprocket
Weldrick
PostPosted: 21:15 - 23 Aug 2011    Post subject: Chain and Sprocket Reply with quote
Need a new one, never had to do this before so I've been looking around, seen a few new ones on Ebay and one I've singled out is a Gold X Ring Chain and Sprocket Kit for £85, it's for a Honda CB600 Hornet 1998, I just need some help on whether this is a good choice or not?
Weldrick
PostPosted: 21:18 - 23 Aug 2011    Post subject: Reply with quote
Sorry, forgot to mention, the make of the chain and sprocket I am looking at is D.I.D
Casper
PostPosted: 21:21 - 23 Aug 2011    Post subject: Reply with quote
DID is one of the top brands.
Chalky.
PostPosted: 21:22 - 23 Aug 2011    Post subject: Reply with quote
DID are right up there.
Well reknown for their quality.
If you look after it well, it'll last the time you have the bike, within reason of course.
SuzukiTom
PostPosted: 21:22 - 23 Aug 2011    Post subject: Re: Chain and Sprocket Reply with quote
is it the D.I.D one?
i bought mine at the end of the year, ive so far had 18k out of it on my bandit but it need replacing now. not bad, and the gold coating on these ones seem to prevent any rust at all. Well worth the money IMO, i D.I.D chains for everything but i think i know the kit your on about on ebay - im after one to![/b]
Weldrick
PostPosted: 21:35 - 23 Aug 2011    Post subject: Reply with quote
Well I've put the order in for a DID chain and sprocket set, £88.44 off Ebay, next step fitting!
SuzukiTom
PostPosted: 21:41 - 23 Aug 2011    Post subject: Reply with quote
have you done one before? its not too much fuss unless you get a really stiff bolt (often front sprock)
Weldrick
PostPosted: 21:44 - 23 Aug 2011    Post subject: Reply with quote
Nope never, I'm not sure whether it's a split link chain or not? If not I don't have the tool to split the chain, I will end up taking it somewhere much less hassle for my very little mechanically minded mind Smile
SuzukiTom
PostPosted: 21:58 - 23 Aug 2011    Post subject: Reply with quote
it is a soft link unfortunatly mate, youll need to split it and youll need to rivet the new chains 'soft link'. you dont specifically need any specialist tools to do it but its recomended to use a proper chain tool if its your first go.
DrDonnyBrago
PostPosted: 08:16 - 24 Aug 2011    Post subject: Re: Chain and Sprocket Reply with quote
Can't go wrong with DID tbh.
stonesie
PostPosted: 10:51 - 24 Aug 2011    Post subject: Reply with quote
To save you some money and gain experiance I would say to do it yourself but buy a split link to suit your chain so you can fit it yourself then take it to a bike garage for them to replace the split link with the rivet link.
To split the old chain grind the heads of the rivets on one link and tap them out with a hammer and punch.
Casper
PostPosted: 11:46 - 24 Aug 2011    Post subject: Reply with quote
Also before you pull the old chain out hook the new one to the broken link and pull it through. This will save a lot of time and hassel fitting the new chain.
SuzukiTom
PostPosted: 13:05 - 24 Aug 2011    Post subject: Reply with quote
if you do go for it yourself remember to leave the chain on until you have undone the front sprocket nut! dont de-linkt he chain first!
philoldsmobil...
PostPosted: 19:17 - 24 Aug 2011    Post subject: Reply with quote
most chain kets come with a rivet link and a split link, so i'd second doing it yourself and just getting the shop to change the split link for a rivet link. I ran a split link on aCBR 600 for a while, and while the side plate never shifted (they are a tight fit and it needed to be pressed on with a small G clamp and a socket) the spring itself did ping off a couple of times.
as mentioned above, first job before doing anything else is undoing the front sprocket if its a single nut job. easiest way is to sit on the bike in gear and with both brakes hard on, and get someone with a dirty great breaker bar and a decent socket to undo it.
Weldrick
PostPosted: 13:34 - 25 Aug 2011    Post subject: Reply with quote
I've managed to get a split link tool and riveter, going to have a crack at it myself I think guys! Spoke to several people on how to do it and they all said it was easy going to check a few youtube vids out on how it has been done. Now a bigger problem is lack of the correct size sockets/spanners! I'm thinking a nice fresh stock of tools before I start to remove the chain is in order!
Weldrick
PostPosted: 13:36 - 25 Aug 2011    Post subject: Reply with quote
I didn't even manage to get down to the front sprocket! The 17mm nut holding the casing on was tight enough, put a lot of weight on the wrench, heard a clunk and that was the end of the wrench! Thank god for owning more than one
The last post was made 15 years, 40 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.47 - MySQL Queries: 13 - Page Size: 88.4 Kb
