af1 frontlight rubber
penis020
PostPosted: 20:16 - 23 Aug 2011    Post subject: af1 frontlight rubber Reply with quote
hi does anyone know where i can buy a frontlight rubber for my af1 sports pro many thanks jamie
PostPosted: 23:20 - 23 Aug 2011    Post subject: Reply with quote
Which bit? Can't remember which headlight you have. UK ones had twin round lights with a (fairly horrible) rubber surround for them. Non UK ones had a letter box shape headlight, and think they had a rubber piece around the headlight inside the fairing, but not sure on this.
Which type have you got?
penis020
PostPosted: 09:53 - 24 Aug 2011    Post subject: frontlight rubber Reply with quote
hi keith
i have the letterbox shape headlight on my sports pro is it just two rubber lugs i need or complete rubber to go around the whole light unit ? also so could i pick your brain about rearlight does this fit on to the number plate holder , do u know what other bike cap will fit my oil tank many thanks jamie
PostPosted: 10:06 - 24 Aug 2011    Post subject: Reply with quote
Looking at the parts list, there is a sticker around the headlight (stops light leaking out all over the place) rather than the rubber surround I thought I remembered.
The headlight bolts in place via a bolt through a rubber grommet on each mount. The grommets are part nuber 81 20 275, and the same part number is also used on the early RS125.
The back light mounts through rubber grommets with a top hat bush through the middle. Part numbers 81 20 223 & 81 21 790. Again also used on the early RS125 (tail light itself is different though).
Need to check the bike to see how the light mounts to the back end. Think it just attaches with a couple of nuts but not sure.
penis020
PostPosted: 13:02 - 24 Aug 2011    Post subject: rubbers Reply with quote
hi keith
i have just typed the parts number in the
aprilia website and
they are not coming up do u know where i can source those parts from many thanks jamie
penis020
PostPosted: 13:08 - 24 Aug 2011    Post subject: Reply with quote
hi,
i found found these ones on the site below
do they look like the right ones?
https://www.bitzforbikes.co.uk/Headlight_Bracket_Rubbers_37-41mm_%28pair%29-ref-9874-606.html
PostPosted: 13:16 - 24 Aug 2011    Post subject: Reply with quote
Those are different.
Can find them here (from various Aprilias that used the same part).
81 20 275
81 20 223
81 21 790
penis020
PostPosted: 20:04 - 24 Aug 2011    Post subject: rubbers Reply with quote
many thanks jamie
The last post was made 15 years, 44 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.57 - MySQL Queries: 13 - Page Size: 59.02 Kb
