fzs600 carb inlet rubbers
snowsurfer
PostPosted: 23:56 - 23 Aug 2011    Post subject: fzs600 carb inlet rubbers Reply with quote
ok needing carb inlet rubbers for my t reg fazer, but the only ones i can find anywhere are the thundercat ones. now i always thought it was the exact same engine in both bikes therefor the same carbs, but cant find confirmation anywhere that they are the exact same
dont want to order the thundercat ones and find they dont fit on my fazer properly because they had different carbs, need them quickly too so quick and helpful responses would be magic!
i had found a set on ebay listed as fzs600 rubbers but also found the thundercat ones from the same seller at 20 quid less, so i emailed the guy and asked if the were the same parts. the next day he had removed the fazer ones from auction, but never replied to my message, which was helpful! Confused
this is the link to the thundercat part https://www.ebay.co.uk/itm/380357679717?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
so can anyone tell me if they are the same or different???
cheers
Past Bike: 07 Honda xr125l
Current Bike: 99 Yamaha Fazer 600
mad4it028
PostPosted: 00:13 - 24 Aug 2011    Post subject: Reply with quote
they have differnt sized carbs so wont be the same im affraid
heres my sorce
https://www.motorcyclespecs.co.za/model/yamaha/yamaha_fzs600_fazer%2098.htm
snowsurfer
PostPosted: 00:21 - 24 Aug 2011    Post subject: Reply with quote
muchas gracias for the quick reply, just need to find a set of fazer ones now Thumbs Up
herulach
PostPosted: 07:43 - 24 Aug 2011    Post subject: Reply with quote
CHR15 wrote:
if its because there cracked on the outside, check the inside carefully.
the cracking doesnt usually go all the way through.
This, I thought mine needed changing, but got the carbs off and they were fine on the inside. Absolute cock of a job to get the bastard things back on though.
YBR 125>FZS600
asok4uuu
PostPosted: 18:51 - 24 Aug 2011    Post subject: Reply with quote
ya, they have differnt sized carbs so wont be the same im affraid
there are diff ones on the net.
snowsurfer
PostPosted: 19:25 - 24 Aug 2011    Post subject: Reply with quote
they are cracked on the outside, so wanted them done. just worth doing now because the engine head is off just now gettin downpipe studs out (old owner welded them in for some spasticated reason) worth gettin them done just now because it is such a bastard to get to as you say
The last post was made 15 years, 43 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.59 - MySQL Queries: 13 - Page Size: 48.28 Kb
