| Mellow Matt |
 Mellow Matt Scooby Slapper
 Posted: 11:43 - 24 Aug 2011 Post subject: Sticky clutch |
I changed the clutch plates and springs in my TLR a couple of weeks ago, and since then I've found that the clutch is sticking (I assume) when cold.
What's happening is that after it's been left a while I'm not able to push the bike in gear with the clutch it. If I rock it back and forth hard enough it'll unstick and then I'll be able to push it, but it'll be harder than before.
Also, if I start it in gear with the clutch in, it'll jerk forward more than it used to. It doesn't have any clutch drag after a few seconds though (i.e. if I hold the clutch in it will just roll freely).
I'm not sure what the cause of this is, and whether it's anything to worry about? The springs I put in claim to be 10% stiffer, so that might be the cause? Or it's some kind of vacuum lock?
Has anyone got any ideas?
Thanks  ____________________ 1999 GSX-R 600, 1999 TL1000R |
| SuzukiTom |
 SuzukiTom Nova Slayer
| Mellow Matt |
| philoldsmobil... |
 philoldsmobil... Renault 5 Driver
| hazza |
 hazza World Chat Champion
| philoldsmobil... |
| Mellow Matt |
| Howling TerrorOutOfOffice |
 Howling TerrorOutOfOffice Super Spammer
 Posted: 01:06 - 25 Aug 2011 Post subject: |
I'm no expert but have done the plates, springs and basket before.
Things i'd check/do.
Inspect the clutch slave for leaks.
Bleed the clutch....testride.
Replace new springs with originals (check the old springs are in tolerance) Whilst the cover is off have a look at the basket..might as well make sure the right amount of plates were put back in.
If the basket has notches deeper than a couple of mm the friction plates with their new tangs don't slot back into place so well.
That's me out of ideas...almost.
Maybe pull out the clutch rod and look for any wear. ____________________ Diabolical homemade music Bandcamp and Soundcloud
The Harry Turner Project |
| devojunior |
 devojunior Brolly Dolly
| SuzukiTom |
| TUG |
 TUG World Chat Champion
The last post was made 15 years, 40 days ago. Instead of replying here, would creating a new thread be more useful? |
