Front Brake Question
TheSmiler
PostPosted: 21:04 - 24 Aug 2011    Post subject: Front Brake Question Reply with quote
Just wondering what are the washers for next to the front break there was two of them on the bike when I replaced the break however went out after a downpour and there is only one left Confused .. will this have any effect as the brake is still tight and does its job ?
herulach
PostPosted: 21:07 - 24 Aug 2011    Post subject: Reply with quote
I don't know which washers you mean, but if you actually mean washers then where is the nut/bolt they were attached to? If random bolts were dropping out of my front brakes i'd be pretty worried.
YBR 125>FZS600
TheSmiler
PostPosted: 21:22 - 24 Aug 2011    Post subject: Reply with quote
Well they are not attached to any bolt they go next to a piece of metal and press against it when the brake lever is pulled. Not going to be riding it tonight anyway so may be best to get a picture tomorrow.
PostPosted: 21:46 - 24 Aug 2011    Post subject: Reply with quote
The mind simply boggles at to what this part might be. The first thing that springs to mind from your description is the brake pad... which is frankly a worry.
I think a picture will be necessary, or an exploded parts diagram showing the relevant part.
As a starter for ten, the make and model of the motorcycle in question would be a step in the right direction.
TheSmiler
PostPosted: 23:10 - 24 Aug 2011    Post subject: Reply with quote
The picture will be on here in the morning hopefuly before I go cinema if not it will be about 2pm. Can't really find a diagram of it online however so for the meantime bike is "Corporal" 1986 Honda CB 125T.
PostPosted: 00:23 - 25 Aug 2011    Post subject: Reply with quote
Ahh.
Possibly the worst brake design ever fitted to a motorcycle since BSAs rod-activated wooden rim brakes.
I suggest you kill it with fire.
Something like this?
https://www.cmsnl.com/honda-cb125t-france_model16530/partslist/F07.html
PostPosted: 00:36 - 25 Aug 2011    Post subject: Reply with quote
If it is a 1986 bike then it will have the normal hydraulic caliper, rather than the cable operated caliper (which was proof that Honda had a sick sense of humour).
As to the part, I can only guess that by washer you mean one of the rubber boots on the pins the caliper slides on.
TheSmiler
PostPosted: 15:53 - 25 Aug 2011    Post subject: Reply with quote
I said I was going upload some photos an here they are sorry about being late but thats busses for you.
Left of the flat head screw is where there was 2 washers with one falling out during the rain I believe.
https://i1236.photobucket.com/albums/ff446/smilingsam1/IMG_0124.jpg
PostPosted: 16:01 - 25 Aug 2011    Post subject: Reply with quote
Err. Eeek.
Shouldn't be a washer there. I would guess that someone has done a real nasty bodge with a washer between the brake lever and master cylinder piston to take up some of the clearance and make the brakes appear firmer.
Sort it out properly. Could be the seals in the master cylinder or caliper, could be the brake hose is on its last legs, could be the pins the caliper slides on need cleaning up and lubing. Could just need bleeding properly.
PostPosted: 16:10 - 25 Aug 2011    Post subject: Reply with quote
Those aren't an original part of the bike implying either the lever or the master cylinder has a bit missing off it. Either that or they are shimming it out because it's worn and loose.
Teflon-Mike
tl;dr
PostPosted: 16:11 - 25 Aug 2011    Post subject: Reply with quote
Kickstart wrote:
Err. Eeek.
Shouldn't be a washer there. I would guess that Teflon-Mike has done a real nasty bodge with a washer between the brake lever and master cylinder piston to take up some of the clearance and make the brakes appear firmer.
Close... cylinder is 'fine'; but when I did exactly what Smiler has done and knock the bludy bike over and snap the lever, 'replacement' lever had too much free-play, hence shimmed with washers, to take up clerance.
Sized so they fitted fairly snugly in the 'bore' of the piston end, they weren't going to fall out, at any time.... unless some twit bent the lever! (In which case, needs new lever, and depending on how it 'picks up' on the end of the Master Cyl piston, either filing or shimming again to suit.
Didn't Snowie tell you that on FB Smiler?
TheSmiler
PostPosted: 16:21 - 25 Aug 2011    Post subject: Reply with quote
hmm don't remember haven't spoke to snowie that much on facebook (it has been playing up though) hence why I asked on here. But now I understand its cool it seems to be picking up allright with out any problems Thumbs Up
Teflon-Mike
tl;dr
PostPosted: 16:42 - 25 Aug 2011    Post subject: Reply with quote
Right, make sure that there IS 'some' free play in the lever and that when the brake is released, the 'cam' that bears on that washer, or end of the brake piston has a small gap... you can play with your feeler guages if you like! Doesn't have to be big, 1/4mm will do, but enough that the piston FULLY returns, when you let go of the lever.
If there's no gap, then the wheel can still turn, but , if the piston cant fully return, it can 'jack up' and each time you brake, pump a bit more fluid into the system until the brakes stay on.
That's what happend, I think to that chap that fitted cheap chinese knock-off levers and had them pump up on him until they locked and stayed locked.
Its a bit like your tappets, if you remember.
That washer was a conveniently sized 'shim', because the lever that I got was a bit 'short' and the gap huge, and the free play enough that the brake light switch would stay 'out' and keep brake light on', and put lever too close to the bar for my big mitts.
As Keith says 'shouldn't be needed with a new lever; so CHECK the clerance with and without, to decide if you need it, or want it.
On Snowie's bike, remember, we did it the other way, and filed down the cam to make more clerance and bring the lever closer to the bar for her little hands, and maintain full lever travel.
ALL PLEASE NOTE: These small 'adjustments' are possible; I have not shown them on open forum because you FUCK WITH BRAKES AT YOUR OWN RISK!
The last post was made 15 years, 41 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 2.53 - MySQL Queries: 13 - Page Size: 87.07 Kb
