How to get rid of engine 'harmonics'?
Nightwingvyse
PostPosted: 20:39 - 25 Aug 2011    Post subject: How to get rid of engine 'harmonics'? Reply with quote
Hi. I bought my second motorbike, a 1999 Yamaha FZS600 Fazer back in January and i absolutely love it. But the one thing i would like to change about it is the harmonic sounds the engine makes. On top of the nice smooth low growl it has, it also has a light hum about two octaves higher, and then a fairly strong whistle another two octaves up. Both additional frequencies increase and decrease with the revs. It sounds like it's nuclear powered Cool . It would be a fantastic sound, but from where i am on the bike, it sounds like the two higher noises are louder than the fundamental growl. Someone told me there was a kit i could put on to balance out the sound. Does anyone know what i should do?
Thanks.
SuzukiTom
PostPosted: 21:17 - 25 Aug 2011    Post subject: Reply with quote
how well serviced is it?!
hmmmnz
PostPosted: 21:21 - 25 Aug 2011    Post subject: Reply with quote
put up a video with these sounds,
im not sure if you are hearing things or that they are just normal motorbike noises, and you are just over thinking it,
there certainly isn't a "kit" to change engine noises,
there is a kit to change the exhaust noises... they call it .. end can Very Happy
the humans are dead
I kick arse for the lord
Bezzer
PostPosted: 21:36 - 25 Aug 2011    Post subject: Reply with quote
Depends what the bike is, some do have balancer shafts that you can alter and which can change the harmonic vibrations and thereby noise to a degree - Honda Blackbird for example.
Don't think there are that many though with DIY adjustable balancers so basically your stuck with it. Mr. Green
Nightwingvyse
PostPosted: 21:37 - 25 Aug 2011    Post subject: Reply with quote
I don't know a huge amount about it's past, but it performs perfectly, and is in a damn sight better condition than the ER5 i had before of the same age. The one thing that i know i'll need to do soon is change the oil and filter, but apart from that it all seems fine. One little thing is that the rev speed at idle wobbles a little.
Air filter?
Teflon-Mike
tl;dr
PostPosted: 21:45 - 25 Aug 2011    Post subject: Reply with quote
You know, we get a lot of people asking questions about 'tuning' thier bikes...... they dont normally mention, 'Octives' and 'pitch' unless its in relation to a chain!
I think you need to check out Super-Trapp exhausts from the states.
They have a baffle pack on the end made from a number of vent plates, which you can add more to or take ones away to change the note, and a 'slip on' clamp you can slide up and down the collector.
Its supposed to be so that on a tuned engine you can optimise the harmonics for carburation; But in your case I think it would be more like playing a bass trombone!
Have fun!
Nightwingvyse
PostPosted: 21:55 - 25 Aug 2011    Post subject: Reply with quote
Have fun!
My reference to the pitches was really just to give the idea of how it sounds.
The best reference i can find is this kind of effect:
https://www.youtube.com/watch?v=Qx8zCrYp7Qk
About 45 seconds in.
0l0dom0l0
PostPosted: 22:39 - 25 Aug 2011    Post subject: Reply with quote
Sounds like you are referring to the gearbox whine.
Get a louder exhaust Thumbs Up
Shaft
PostPosted: 00:46 - 26 Aug 2011    Post subject: Reply with quote
Do Fazers have a piggyback alternator, the same as XJs?
Their drive mechanism contributes a high pitched whine, which you can't do anything about, other than drown it out with a louder pipe.
PostPosted: 00:54 - 26 Aug 2011    Post subject: Reply with quote
Could be induction noise. The sound of the air being sucked into the engine through the airbox. A different make of air filter may alter this..
Can I suggest earplugs?
PostPosted: 04:41 - 26 Aug 2011    Post subject: Reply with quote
All the extraeoneous noises mean is that your engine is in fine fettle. Ride it for 10 or 15 thousand miles and they will go away - or at least, you won't notice them anymore.
jjdugen
PostPosted: 07:03 - 26 Aug 2011    Post subject: Reply with quote
A lot of these 'unmechanical' noises you hear are caused by the 'clean air' stuff fitted to most modern bikes. I'm working on a Kwak ZZR600 at the moment. Up to 3K RPM it was makeing an intrusive chirping noise. On investigation, Kawa have fitted the most complex of engine breathers that include two reed valves in the rocker cover. One of the petals had split and was causing this wierd noise. Then, it also has an induction vacuum activated breather that vents into the airbox. This makes a rattling noise most noticable at slow speeds.
The simple cure is to remove the lot! Peace and quiet at last.
Nightwingvyse
PostPosted: 15:44 - 26 Aug 2011    Post subject: Reply with quote
I read about the air filter being able to change an engine sound. I might look into it. I'll take it round to my local mechanic and see what they think too.
I would prefer not to get a louder exhaust to drown it out, as i don't want to be one of those dcikheads with a motorbike way louder than it needs to be.
As for earplugs, by complete coincidence i've just bought a really good pair for the wind resistance at high speeds. But the other engine sounds aren't unpleasantly loud or nasty, they just sound out of balance with each other. From where i am on the bike, i can't hear the base engine sound at all unless i'm doing 4k+.
Lipsmoker
PostPosted: 16:25 - 26 Aug 2011    Post subject: Reply with quote
To really change the pitch you're going to need one of these depending on your bike
Carburetors
https://ep.yimg.com/ca/I/stringsandbeyond_1720_223080.jpg
Fuel injected
https://www.howtotuneaguitar.org/images/electronic-guitar-tuner.gif
Four wheels move the body. Two wheels move the soul.
ThoughtContro...
PostPosted: 17:04 - 26 Aug 2011    Post subject: Reply with quote
Could always use one of these
https://files.effectsdatabase.com/gear/pics/boss_ps-2_002.jpg
tho not these
https://www.sweetslyrics.com/images/img_gal/11496_Pitchshifter1.jpg
Prize cunt
The last post was made 15 years, 87 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.63 - MySQL Queries: 13 - Page Size: 93.45 Kb
