Clunky gear changes?
Blackrandomap...
PostPosted: 06:52 - 26 Aug 2011    Post subject: Clunky gear changes? Reply with quote
hey all,
I been getting clunky gear changes, no matter how tight or loose i adjust the chain, Mainly going down the gears at high revs,
could it be time for new chain and sprockets?
had the bike about 8 months now and never changed them so not sure how long they have been on the bike,
I have done about 5k on them and i ride it hard pretty much all the time,
Am i on the right track,
Its a 2000 r6, and i have already tried slightly heavier oil and it made hardly any difference!
Thanks
James
1x 2001 Yamaha R6 1x 2000 Yamaha R6 !For Sale! £2500 1x 2003 Cbr600rr Racebike 1x 2004 Wr450 Sumo 1x 2001 Ktm520 Sumo
Fizzer Thou
PostPosted: 11:21 - 26 Aug 2011    Post subject: Reply with quote
Does the chain pull off the back of the rear sprocket by more than about 5mm?If it does then it may well mean that you need a new chain.Whenever I have fitted a new chain and sprocket set,which is recommended,the differance is chalk and cheese.
A friend with a Yam R6 fitted some lightweight 520 size chain and sprockets and they wore out really quickly.He went over to a quality 530 size and has yet to need to adjust it after 8k miles.
Always have a 'Plan B'
Blackrandomap...
PostPosted: 14:40 - 26 Aug 2011    Post subject: Reply with quote
Hmmm, its got a 530 chain on it already, tbh i cant really see any visible signs of wear and tear!
I have the same problem ages ago but that was with my old 5eb gearbox
little confused on this one
Ariel Badger
PostPosted: 18:46 - 26 Aug 2011    Post subject: Reply with quote
Is the clutch adjusted properly?
Blackrandomap...
PostPosted: 19:44 - 26 Aug 2011    Post subject: Reply with quote
Tbh, i didnt think of the clutch Confused
I like my clutch to bite at the end of the lever so im not sure that is the problem, I messed about and set the clutch up properly when i changed the gearbox, Will check it over again in the morn tho, Ta
The last post was made 15 years, 87 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 0.28 - MySQL Queries: 13 - Page Size: 43.88 Kb
