| devojunior |
 devojunior Brolly Dolly
| stinkwheel |
 Posted: 11:59 - 26 Aug 2011 Post subject: |
If it has a split link on, you can take the clip off and remove the chain then put it back on again. It is critically important that the closed end of the clip faces the direction of rotation.
https://www.teebeemotorcycles.co.uk/ProductImages/renthal_link.jpg
If it has a rivett link, you would destroy it when you remove it. You need a special tool to fit a rivett link which pushes the pins through then deforms the end to stop them coming out. You would need to fit a new one having removed the old one.
A rivett link can be harder to identify, look for one with dimples in the end of the pins.
https://www.sportbikes.net/forums/attachments/help-me-fix/199521d1273395186-rivet-link-chain-ruined-rivet-link-done-small.jpg
You can also get endless chains where all the links are the same. To remove this you would need to remove a link (which would destroy it) then refit with a rivett link.
The other way would be to drop the swingarm and remove it in one piece.
My personal oppinion is that split links are dangerous and have no place on a bigger bike having has several fail in the past.
My advice would be that if it is endless or has a rivett link, you should just work around it.
If you take the wheel out, you'll be able to get most of the chain into a tub to clean it. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| whitedevil |
 whitedevil World Chat Champion
| Fizzer Thou |
 Posted: 12:36 - 26 Aug 2011 Post subject: |
I took the right opportunity to clean the chain while I had the swingarm out to lube the bearings.
https://i666.photobucket.com/albums/vv23/WiNot_Rhencullen/BikesBikesBikes348.jpg
It was easier to do without being on the bike,but not difficult to clean when the back wheel is out. ____________________ Just talk bikes.What else is there?
Always have a 'Plan B' |
| devojunior |
| Tenko |
 Tenko Could Be A Chat Bot
| stinkwheel |
| whitedevil |
| Tenko |
The last post was made 15 years, 87 days ago. Instead of replying here, would creating a new thread be more useful? |
