Changing gear without the clutch
Toccs
PostPosted: 14:08 - 26 Aug 2011    Post subject: Changing gear without the clutch Reply with quote
So today on my way to work i accidently changed gears without using the clutch, now i always thought it was impossible to do that.
Is it bad for the bike, and should i be doing it?
crackfinder
PostPosted: 14:21 - 26 Aug 2011    Post subject: Re: Changing gear without the clutch Reply with quote
It's fine...I do clutchless changes a lot, particularly when having a.....errr......."spirited" ride Mr. Green Thumbs Up
don't change down without using the clutch tho Thumbs Up
Yamaha FZS600 Fazer (gone but not forgotten). Current - Kawasaki ZX6R A1P
Toccs
PostPosted: 14:36 - 26 Aug 2011    Post subject: Re: Changing gear without the clutch Reply with quote
So changing up is ok just not down?
PostPosted: 15:37 - 26 Aug 2011    Post subject: Reply with quote
You [WILL/WON'T] shag your gearbox doing this, bikes [ARE/AREN'T] designed for it.
There, that's both sides of the argument out of the way.
Germ
PostPosted: 15:51 - 26 Aug 2011    Post subject: Reply with quote
Regardless of whether it does or doesn't cause damage it's better not to change gear without using your clutch.You'll pick up enough bad habits as it is without adding any unneeded extras Smile
PostPosted: 16:16 - 26 Aug 2011    Post subject: Reply with quote
On all the bikes I owned aside from the RS.... i've done clutchless up and down after 2nd gear. Still do... on the 750 and 125.
My 125 is very snatchy when doing it though...
crackfinder
PostPosted: 18:05 - 26 Aug 2011    Post subject: Re: Changing gear without the clutch Reply with quote
Changing up is fine, just come off the gas a bit as you would if you were using the clutch, I've never tried changing down without the clutch and would presume it's trickier....matching road speed so you don't lock the back wheel...
Looks like ##Paddy## will be able to tell you more.
TBH there isn't much point to clutchless gear changes apart from if you were "racing"...and just being lazy I guess.
dazzzaa
PostPosted: 18:28 - 26 Aug 2011    Post subject: Reply with quote
if its easy and undamaging to change gears without using the clutch why do they still sit it on your left handle bar?? why not disregard it altogether??
1988 VFR 750-f,,,,binned on duncton hill. current-1993 vfr 750-f
neil.
PostPosted: 19:28 - 26 Aug 2011    Post subject: Reply with quote
Nearly 40'000 miles of doing it (changing up, never down!) half the time on a YBR and never had an issue...
PsychoHippy
Jammy Git
PostPosted: 19:35 - 26 Aug 2011    Post subject: Reply with quote
Could be because it's very handy when you come to a stand still Wink
I spend all my money on bikes and beer, the rest I simply waste!
Slacker24seve...
PostPosted: 16:04 - 30 Aug 2011    Post subject: Reply with quote
What does a quickshifter on a sports/race bike do? Thats right, kill the ignition for a split second as you change gear. No use of the clutch at all. Around town and at slow speeds then yes, its rather handy.
No really recommended from first to second but from then on its fine; a little upward pressure on the pedal, roll off the throttle slightly and it just clicks in. As Cracker said its far better on a spirited ride. Wink
Banger rallies are ace
PostPosted: 16:09 - 30 Aug 2011    Post subject: Reply with quote
Done properly it shouldn't do any damage at all. However probably far easier to make a mess of it than when using the clutch.
PostPosted: 16:14 - 30 Aug 2011    Post subject: Reply with quote
Only ever had an issue on the 125 where I knock it down with no clutch and its like 3rd into 2nd... Rev counter would be handy Laughing
But the 750 gets knocked up and down through the gears (aside from down to 1st) and havent had any issues yet Thumbs Up
PostPosted: 17:21 - 30 Aug 2011    Post subject: Reply with quote
My bandit has a slick gearbox and clutchless changes are no more difficult than loading the lever gently and partial-chopping the throttle momentarily to unload the gears.
My xj1100 would never achieve this though with it's heavy gearbox action.
All depends on the bike. You'll find that there is a 'sweet spot' in the rev range that makes it effortless whilst other RPM/load ranges will makeit a flaky undertaking.
The last post was made 15 years, 83 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.59 - MySQL Queries: 13 - Page Size: 82.7 Kb
