2 stroke running problems
caferacer333
PostPosted: 21:22 - 26 Aug 2011    Post subject: 2 stroke running problems Reply with quote
hey guys
im fixing a 2stroke 100cc twist and go moped, the rider says that after a while of riding it dies, now knowing ped riders that probably means full throttle most places, so first thoughts were over heating, any other suggestion??
many thx
callum
...... classics? choppers? sport?.... not fussed aslong as its got two wheels...
Martay
PostPosted: 22:07 - 26 Aug 2011    Post subject: Reply with quote
Vacuum lock in the fuel tank?
Sparkplug fouling?
Eat well, poo hard Very Happy
Drives: Cavalier 2.0 16v
at106
PostPosted: 08:55 - 27 Aug 2011    Post subject: Reply with quote
If it is only dieing at full throttle then it could be lean seazing. So first i would check that the carb isnt blocked and that it is jetted correctly. Also check the colour of the spark plug, it should be brown ish.
bradh511
PostPosted: 09:16 - 27 Aug 2011    Post subject: Reply with quote
if it a paggio or gelria with the coil and cdi combine .. i had problems with this on my old bike .. the coild started to make the bike run like shit and cut out and then wouldnt no run at all
bouncerdove
PostPosted: 13:06 - 27 Aug 2011    Post subject: Reply with quote
Hi. Had the same problem with a ped once. It was the float level to low, causing the fuel to run out after a short while at full throttle, If it was kept at lower throttle use it ran ok.
Regards bouncerdove
The last post was made 15 years, 86 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.04 Sec - Server Load: 1.03 - MySQL Queries: 13 - Page Size: 42.54 Kb
