| MickC |
 MickC Spanner Monkey
 Posted: 12:27 - 28 Aug 2011 Post subject: Stuck Barrels |
In the process of stripping my top end. Heads off but the barrels are stuck. Its a 1979 cb900, I've had to hacksaw the bolt at the bottom of the barrels (head was rounded off) and no amount of persuasion is getting them to break their seal. Any suggestions no matter how brutal will be welcome. The barrels are scrap ( I have a brand new set and pistons to go on so damage to the old ones doesn't matter - already tried a lump hammer ) ____________________ XX XXXx
Previous: CG125,XS250 (converted to 400),Z250A, GPZ550, Norton Commando, XS500, 78 Laverda Jota, GPZ1100,Harris bonneville, XV750 (mono shock),TR1 |
| unitynotsocri... |
 unitynotsocri... Banned
 Posted: 13:04 - 28 Aug 2011 Post subject: |
Angle grinder?If thats not possible then drill through the old bolt and scarpe it out. ____________________ nearly a normal tax paying tosser.......with ferrileness suzi100,cg125,cb125scb100n,cb175,cd100,cj250t,kh250,c15,125 bantam,super 6,rickman gs750,xt500,250rs,dt175,lifan125,dolomite1850,metro,Morris220ld,morrisfg,leyland princess,range rover,corsa,vw camper .now struggling with legs. MORE ORDER = MORE CHAOS |
| MickC |
 Posted: 13:34 - 28 Aug 2011 Post subject: |
Nice one, just cut round where the bolt was and off they came. ____________________ XX XXXx
| unitynotsocri... |
 Posted: 13:59 - 28 Aug 2011 Post subject: |
whne putting the barrels back on make sure the rings are all lined up correctly(three rings per piston ,ring gap usually 120 degree apart) and oil the piston tops/rings before lowering the barrels,good luck. ____________________ nearly a normal tax paying tosser.......with ferrileness suzi100,cg125,cb125scb100n,cb175,cd100,cj250t,kh250,c15,125 bantam,super 6,rickman gs750,xt500,250rs,dt175,lifan125,dolomite1850,metro,Morris220ld,morrisfg,leyland princess,range rover,corsa,vw camper .now struggling with legs. MORE ORDER = MORE CHAOS |
| stinkwheel |
The last post was made 15 years, 85 days ago. Instead of replying here, would creating a new thread be more useful? |
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.04 Sec - Server Load: 0.39 - MySQL Queries: 13 - Page Size: 44.9 Kb
