| cozmoss11 |
 cozmoss11 Two Stroke Sniffer
| Daytona Paul |
 Daytona Paul Scooby Slapper
 Posted: 06:42 - 29 Aug 2011 Post subject: |
Keep everything smooth.
Use the throttle 'progresively' rather than 'snatching' it open.
Use the brakes the same, 'ease and squeeze' is a good thing to remember, if you are stopping normally just 'ease' the front brake on gently and just use a small amount of rear. If you need to stop quicker ease the front brake on and continue 'squeezing' (bit like squeezing a lemon) and apply a little rear.
Slow down a little for the corners/roundabouts etc and try not to lean the bike too much. Relax!
Wear waterproof clothing to keep yourself warm and dry, it will help your concentration. ____________________ www.angliaroadtraining.com
CBT FROM ONLY £85
Back to Biking Refresher Day £99! Book with a friend and get 20% Discount! |
| Rogerborg |
 Rogerborg nimbA
 Posted: 07:08 - 29 Aug 2011 Post subject: |
Also: do it. You're not going to learn how (just) by reading about it. ____________________ Biking is 1/20th as dangerous as horse riding.
| anthony_r6 |
 anthony_r6 World Chat Champion
| -Savage- |
 -Savage- World Chat Champion
 Posted: 08:25 - 29 Aug 2011 Post subject: |
| AnPhonEh wrote: | Avoid drain covers where possible, especially on while turning. |
Don't go out of your way to avoid drain covers if it means altering your line.
A bad line, or one that you alter mid corner could end up a lot worse than the chance of hitting a drain cover.
Try and take a line which means you are less lent over though, but do not put yourself in a bad road position to do so.
Smooth with the controls, and plan ahead, more so than usual. Give yourself double the breaking distance, and keep your speed down a bit in built up areas. car drivers visibility will be affected by the weather too.
Get good gear, few things sap concentration more than being wet and cold, so make sure that for the duration of your journey you will stay warm and dry.
Keep your visor clean and scratch free, and use a pinlock or anti fog application to help your own visibility.
Consider hi-viz or at least make sure your lights are on, and the lenses are clean.
Keep your tyres in thread.
Be confident, if you are nervous you will find it harder to be smooth. Nervous makes you tense, and jerky, confident makes you relaxed and smooth. the smoother you are in low grip the better.
Rain on the roads should not lower the grip levels enough to affect a modern tyre that much. so don't panic when it rains. Just have faith in the tyres and try and give yourself as much time as possible to execute any turns/manurers. ____________________ My Bikes - - - Royal Enfield 500 with sidecar, VFR800, CBR600FX,
| Chalky. |
 Chalky. World Chat Champion
| Chalky. |
 Posted: 08:29 - 29 Aug 2011 Post subject: |
Smoothness is the key.
Try to avoid shiney surfaces, manhole covers, white lines etc.
Remember to be steady on the brakes, leave plenty of room in regard to the vehicle infront.
And man up a bit, you've got a lot more grip than you think.
| doggone |
 doggone World Chat Champion
 Posted: 08:53 - 29 Aug 2011 Post subject: |
Don't do it, both you and your bike will shrink  |
| Rogerborg |
 Rogerborg nimbA
| Chalky. |
| chris-red |
| Winnefc |
 Winnefc L Plate Warrior
| dannyjohnson |
 dannyjohnson Banned
 Posted: 03:47 - 30 Aug 2011 Post subject: |
Ride faster, gets you out the rain more quickly. i agree 100%https://www.imgquick.com/images/43.gif ____________________ dannyjohnson |
| SmokeyBaker |
 SmokeyBaker L Plate Warrior
 Posted: 07:15 - 30 Aug 2011 Post subject: |
Get on an have a go, like you I avoided it until I read that avoiding riding in the rain was not a good thing and after several rideouts recently I would agree, we have left in glorious sunshine only to ride into heavy down pours. Ride locally in light showers to build your confidence, it will come.
Good luck  |
| Whatsername |
 Whatsername Borekit Bruiser
 Posted: 12:26 - 30 Aug 2011 Post subject: |
When I first started I was trying to avoid going out in the rain but as someone else said you go out thinking it's glorious sunshine all day only to get caught up in a shower. I think I have been out twice in the rain now but am going to have to start going out more often otherwise I will never get out on the bike. I want to start going to work on it soon too so I will have to get used to it.
This is a really helpful thread  |
| John933 |
 John933 Crazy Courier
 Posted: 12:42 - 30 Aug 2011 Post subject: |
You are worried about riding in the rain on a 50cc bike. Hell my starter motor is bigger than that. How can you get into trouble on a 50
John933 ____________________ My trip |
| Howling TerrorOutOfOffice |
 Posted: 12:52 - 30 Aug 2011 Post subject: |
Wet roads are a good time to experiment with body positioning.
You can still corner at sensible speeds. Shifting some extra weight to the inside of a corner will keep the bike more upright. I had to do this when my toes and pegs were touching down mid corner. Was 2up with luggage and a dry road but the principles the same.
[edit] wet roads affect all 2 wheeled transport. During the Tour de France i noticed riders hanging off like monkeys to gain a bigger contact patch. ____________________ Diabolical homemade music Bandcamp and Soundcloud
The Harry Turner Project |
The last post was made 15 years, 83 days ago. Instead of replying here, would creating a new thread be more useful? |
