| fbmbmx |
 fbmbmx Scooby Slapper
| MickC |
 MickC Spanner Monkey
 Posted: 10:48 - 29 Aug 2011 Post subject: |
In the Master cylinder there is a tiny hole that can get blocked, it's the return not the main feed, but it's usually close to the main feed hole. Also are the plunger seals in good condition?
And is the Master cylinder powerful enough to operate the callipers? (you can't usually change the calipers without looking at the master cylinder, some 'pump' at different rates)
As an after thought are brake piston seals in good condition? ____________________ XX XXXx
Previous: CG125,XS250 (converted to 400),Z250A, GPZ550, Norton Commando, XS500, 78 Laverda Jota, GPZ1100,Harris bonneville, XV750 (mono shock),TR1 |
| fbmbmx |
| Kickstart |
 Kickstart The Oracle
| MickC |
 Posted: 19:46 - 29 Aug 2011 Post subject: |
It's below the reservoir, but it is most likely that the master cylinder is no use to the calipers ____________________ XX XXXx
| fbmbmx |
| DrDonnyBrago |
 DrDonnyBrago World Chat Champion
| Kickstart |
| Souleh |
 Souleh Trackday Trickster
| Kickstart |
| fbmbmx |
| Kickstart |
The last post was made 14 years, 146 days ago. Instead of replying here, would creating a new thread be more useful? |
