ZZR 250 Rear Wheel Bearing Replacement
deleted111
PostPosted: 14:57 - 29 Aug 2011    Post subject: ZZR 250 Rear Wheel Bearing Replacement Reply with quote
Afternoon!
Changed rear sprocket carrier bearing on the ZZR earlier and thought I'd do the rear wheel bearings whilst I'm at it.
Struggling to find a way to remove them??
Changed the front wheel bearings the other week and assumed the back would be as simple but it's not - there's no edge on the inside for me to get the flat head screw driver on to? It's straight through, with like, a rod between both wheel bearings?
One wheel bearing - rod - other wheel bearing
is it a case of removing the circlips, smacking one wheel bearing to remove the other one, remove the rod, then remove the remaining bearing using the same method I used to get the front wheel bearings out??
Cheers in advance!
Steve.
Fisty
PostPosted: 15:01 - 29 Aug 2011    Post subject: Reply with quote
Put your screwdriver halfway down the spacer tube and tap it gently sideways. It should move a couple of mm to one side, giving you an edge of a bearing to work on.
Fatter and faster than Fret
deleted111
PostPosted: 15:04 - 29 Aug 2011    Post subject: Reply with quote
Ah!
Nice one, cheers.
Will report back!
Karma Thumbs Up
Casper
PostPosted: 15:15 - 29 Aug 2011    Post subject: Reply with quote
Guess which twat changed his the other month and forgot to put the spacer back in. Oops.
deleted111
PostPosted: 17:48 - 29 Aug 2011    Post subject: Reply with quote
^ oops lol
Panic over guys, cheers!
Bearings out and replaced, took the opportunity to clean the swing arm whilst I was at it Laughing
Thanks,
Steve.
The last post was made 14 years, 119 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.04 Sec - Server Load: 0.43 - MySQL Queries: 13 - Page Size: 43.02 Kb
