Cbr 125 question
Whatsername
PostPosted: 17:18 - 30 Aug 2011    Post subject: Cbr 125 question Reply with quote
Hi guys
Our cbr 125 wont start if its in gear only neutral. Is it meant to do this or is it a fault? If it is what is the fix?
Thanks
Microcut
PostPosted: 17:41 - 30 Aug 2011    Post subject: Reply with quote
If it has an electirc start then it should start in first gear. Only suggestions i can muster are:
Clutch in if you're wanting to start in first and making sure you're not attempting this with the side stand down.
Only obvious things i can think of atm...wait for the bright sparks Smile
J.M.
PostPosted: 18:10 - 30 Aug 2011    Post subject: Reply with quote
This is normal behaviour for the bike - it's a safety measure.
The bike will not start in 1st gear or with the side stand down. If you do want to start the bike in 1st gear then pop the clutch in and press the electric start.
You can also start the bike with the side stand down (with a bit of difficulty from a cold engine) by popping in the clutch - but the engine will stop once you release the clutch so long as the side stand is still down.
2004 R1 & 2018 XSR900
PostPosted: 18:31 - 30 Aug 2011    Post subject: Reply with quote
If its in gear AND the stand isnt down AND the clutch is in, it should start.
All 3 are needed..
If it doesnt, there are 2 wires going to the clutch lever, take them off and join them together.
Try it now..
Could be your clutch switch is dead... or just not connected well. The CBR im using now doesnt start in gear for that exact reason.
Whatsername
PostPosted: 22:04 - 30 Aug 2011    Post subject: Reply with quote
I meant it was in gear clutch in stand up. Sorry if that wasnt clear. Smile
PostPosted: 07:34 - 31 Aug 2011    Post subject: Reply with quote
Then it could be the switch on the clutch lever.
The last post was made 15 years, 82 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.04 Sec - Server Load: 0.18 - MySQL Queries: 13 - Page Size: 46.7 Kb
