First Problem......
dannymassive
PostPosted: 22:18 - 30 Aug 2011    Post subject: First Problem...... Reply with quote
So, here's how it goes...... Bought my first bike a few weeks ago, ordered a Motad Venom Exhaust and fitted it today. First ride round the block and "Tada!!" - the speedo doesn't work!? Seconding this, the RED "FI" light comes on, then starts flashing.....ok, so I ride home and turn engine off (The bike is still running fine). Had a look around bike to see if there's any loose connection that are obvious to the eye - not a sausage. Tried bike again, speedo working and RED "FI" light not on...... hmmmmmmmm
Is this a pure co-incidence that this has happened as the Exhaust has been changed or is the exhaust causing issues with my electronics!?? I'm not a complete "dim whit" am I? Only I was pretty darn certain that there was no link between burnt fuel gasses going through a metal pipe and electric cables that are nowhere near each other!!!!!
Have tried to replicate the problem and now it won't do it - I mean I know that's a good thing for now, but what caused it and am I going to have problems in the near future? I.e. Is a sensor slowly dieing on me!?
BTW the bike is a 2008 Honda CBF600n with Fuel Injection not carb.
Anyone else ever had this problem?
Previous Ride's - '01 Aprilia SR125 (Sold) '08 HONDA CBF600n (Sold) '96 CB500 (Sold) '01 FZS 1000 (Sold) '06 CB1300SA (Sold) '07 CB600F Hornet (Sold) - '93 Suzuki Savage LS400 (Sold) '98 Honda VTR1000 Firestorm (Sold) '05 CB600F Hornet (Sold) '01 FZS1000 Fazer (Sold) 2016 Harley Davidson Street Bob SE (Sold) '02 Kawasaki ZX9R (Sold) '98 CB600F Hornet (Sold) '04 Suzuki Bandit 1200s (Sold) '13 Yamaha FZ1-N
MaybeGuy
PostPosted: 22:36 - 30 Aug 2011    Post subject: Reply with quote
you probably unplugged the exhaust servo.
dannymassive
PostPosted: 22:44 - 30 Aug 2011    Post subject: Reply with quote
Exhaust servo?
There was one bolt that held the original exhaust to the bike and then a clamp that held the pipe to the collector pipe.....nothing else was connected to the exhaust!?
dannymassive
PostPosted: 12:41 - 31 Aug 2011    Post subject: Reply with quote
Seems to be fine now.....Will update again if I have the problem again.
dannymassive
PostPosted: 21:16 - 31 Aug 2011    Post subject: Reply with quote
Problem is defiantly intermittent.......Have phone exhaust manufacturer and they have confirmed that this is nothing to do with the exhaust being fitted. So, I guess it's a dodgy sensor......
Can anyone enlighten to the guilty culprit!?
Bezzer
PostPosted: 22:37 - 31 Aug 2011    Post subject: Reply with quote
Have you got the handbook/manual?, the fault codes are in there. On a Honda you count the FI light flashes, long one = 10, short one = 1, if it's an ongoing problem it will keep repeating the code, if it's reset itself then there is a block you short out to access the fault memory and again count the flashes. Dunno exactly where the block is on your bike, you need the manual for that and to tell you what the code number means.
DrDonnyBrago
PostPosted: 12:15 - 01 Sep 2011    Post subject: Re: First Problem...... Reply with quote
Does the CBF use an old CBR engine by any chance? I had a similar problem on my CBR and I ended up changing the speed sensor.
There will be a service connector somewhere that you can bridge and read the FI code. It will be something along the lines of speed sensor or wiring fault if it is what I think it is.
The speed sensor is a little electromagnetic pickup in the crankcase, honda can't seem to make them (or cam chain tensioners) for toffee. If access is good then swapping them is VERY easy.
I wrote a how to when I changed mine, most of it is model specific but the last section is applicable.
https://cbrforum.com/forum/how-mechanical-40/howto-f4i-speed-sensor-swap-110034/
dannymassive
PostPosted: 21:07 - 01 Sep 2011    Post subject: Reply with quote
Thanks for your help DonnyBrago & Bezzer - It was indeed the speed sensor that was causing the problem and indeed it is an old CBR engine - a detuned version that is! Cheers guys.
DrDonnyBrago
PostPosted: 07:46 - 02 Sep 2011    Post subject: Reply with quote
Pop it out and clean it and if that doesn't work swap it out. They cost silly money direct from Honda (£120ish) but I got one from a breaker for £25.
Good luck Thumbs Up .
The last post was made 15 years, 60 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.51 - MySQL Queries: 13 - Page Size: 62.01 Kb
