| mrr1 |
 mrr1 Traffic Copper
 Posted: 19:56 - 31 Aug 2011 Post subject: knackered rear shock?? |
right - I ride a MY2000 first gen fazer 600 to and from work every day - about 60 miles round trip. Bike is well maintained (albeit by myself) and currently has 34k on the clock. Until about 2 weeks ago all was well then one morning I found the front tyre (cheapo Maxxus touring 120/60 17 with 5k on it) was totally flat. I pumped it back up and rode off very carefully stopping every couple of miles for a "bloody good squeeze" (and, yeah, I know what you're going to say - why TF didn't I take the cage.....). Alls been well for the 2 weeks since with no pressure drop whatsoever - possibly down to the Goop in the tyre. There are no tacks, screws, whatever and the valves seems fine. Front forks had an oil change about 7k ago - slightly thicker than std oil & forks dropped 5mm. Bars are Renthals lowish profile.
Rear has been raised 25mm and rear is fitted with a matching Maxxus cheapo special with less than 1k under its belt and running at 42psi. All the rear end was stripped, cleaned and repacked with grease a year ago (very slight amount of corrosion here and there but nothing of any note. )
I've noticed over the past three days that the back end feels like its "wandering" a bit - you know that icky feeling you get when you get a rear puncture - not that bad but something generally "not quite right". The rear shock is the original so I know its done pretty bloody well to carry my 17stone of lard around for the past 20k miles and still be in one piece.
I know I need to get the shock swapped or refurbed pretty soon but want to know whether I'm just being paranoid or its a sure sign to sort the shock or I'm simply seeing the symptoms of cheapo tyres or there's something else I need to be looking at. Current lack of funds means I can't go splashing out hundreds on anything that "might" be the cause or would simply make an old bike a little bit better.
Any advice greatly appreciated ____________________ TRX850, TDM900, ST1300, CB650SC Nighthawk, ragtop Saab, gym membership, messy divorce, large chested blonde fiance
Damn, I'm loving my midlife crisis. |
| neatbik |
 neatbik World Chat Champion
| mrr1 |
 mrr1 Traffic Copper
| SuzukiTom |
 SuzukiTom Nova Slayer
| 0l0dom0l0 |
 0l0dom0l0 World Chat Champion
 Posted: 21:58 - 31 Aug 2011 Post subject: |
42 and 36 is what I run on my Fazer
What's the preload set to? Might be worth upping that a couple if you can.
Other than that not much else I can suggest really. ____________________ CBT Passed: 30/08/2009, Theory Passed: 31/08/2010, Mod 1 Passed: 6/9/2010, Mod 2 Passed: 13/09/2010. Restriction ended 13/09/2012.
Bikes: 2007 Derbi GPR 50, 1998 Yamaha Fazer 600 (written off), 2002 Yamaha Fazer 600, 1994 CBR 600F, 2003 Triumph Daytona 600, Kawasaki ZX6R J1.....Current: 2006 Yamaha FZ6, 1998 Suzuki TL1000R and a Honda VFR 400 NC30. |
| mrr1 |
 mrr1 Traffic Copper
 Posted: 06:10 - 01 Sep 2011 Post subject: |
| SuzukiTom wrote: | ok with the bike upright, compress the rear shock with you hands on the rear seat - if it takes longer then one complete second to return to the original position, it looks a look at.
check around the shock for any leaks too.
id check the rear wheel bearing for play and the linkage and swing arm bearings for play too.
finding a used shock, thats the cheapest method, a rebuild could cos up to 200£ at some places. |
cheers - bike returns to proper height pretty quickly. Static sag is 10 - 12mm, rider sag is approx 30mm - seemingly both ok (which on a 34k budget shock is odd I would have thought.......)
can't seem to find any play in rear wheel but whats the best way to check?
brooks suspension do a basic rebuild for £100. There's a guy on t'interweb selling a mk2 fazer 600 shock for £75 - reckons its only covered 750 miles. Seems too good to be true..... ____________________ TRX850, TDM900, ST1300, CB650SC Nighthawk, ragtop Saab, gym membership, messy divorce, large chested blonde fiance
| Wafer_Thin_Ham |
 Wafer_Thin_Ham Super Spammer
| Snorty |
 Snorty World Chat Champion
| Wafer_Thin_Ham |
| Snorty |
| mrr1 |
 mrr1 Traffic Copper
 Posted: 11:25 - 01 Sep 2011 Post subject: |
| Big_Ham wrote: | | snorty wrote: |
£25 to get one refurbed?! Where do you get that done? |
There should be a more in there somewhere.  |
my only issue is that I need the bike every day - using the cage costs a fortune (bridge tolls, 26mpg, etc)
I'm going to get e second shock so at least whilst one is being refurbed the bike can still run.
Actually I dialled up the rear preload to top setting which helped a deal.
I then dropped the forks another 4mm. I don't know if that helps the rear end but the front is now so bloody fickle and hyperactive it stops me worrying about what the back end is doing........... ____________________ TRX850, TDM900, ST1300, CB650SC Nighthawk, ragtop Saab, gym membership, messy divorce, large chested blonde fiance
| mrr1 |
 mrr1 Traffic Copper
The last post was made 14 years, 182 days ago. Instead of replying here, would creating a new thread be more useful? |
