How To Clean Needle Bearings?
sparkywilliam...
PostPosted: 09:37 - 01 Sep 2011    Post subject: How To Clean Needle Bearings? Reply with quote
Best way of cleaning out the old grease and any other rubbish in there before new Moly goes in?
Do i just wipe it out with a dry rag or can i use parrafin,degreaser?
Thanks All
Mark
Previously CG125,YBR125 Now GSF600 Bandit
DrDonnyBrago
PostPosted: 09:45 - 01 Sep 2011    Post subject: Re: How To Clean Needle Bearings? Reply with quote
I would use paraffin.
sparkywilliam...
PostPosted: 10:28 - 01 Sep 2011    Post subject: Reply with quote
Thanks mate,
Soak them in it? rub and them/dry gently and then blow out gently with air compressor?
DrDonnyBrago
PostPosted: 10:35 - 01 Sep 2011    Post subject: Reply with quote
sparkywilliams wrote:
Thanks mate,
What I would do is:
Soak them in the paraffin, move the bearing needles around to release any grit and dirt, agitate them with a soft brush then spray them with a little brake cleaner to remove the paraffin, the brake cleaner evaporates very quickly and doesn't leave residue.
EDIT: If it is close to other bearings you wont be cleaning out and regreasing then I would avoid using the brake cleaner as it could remove grease from those too.
sparkywilliam...
PostPosted: 10:36 - 01 Sep 2011    Post subject: Reply with quote
lovely, that's what i'll do then!
PostPosted: 12:01 - 01 Sep 2011    Post subject: Reply with quote
The problem with cleaning them with chemicals is that you have to be REALLY REALLY sure you've regreased them well otherwise you could actually be making the problem worse. The absolute best thing you can do is to merely replace them.
Personally, I'd never clean bearings. I'd only ever just re-grease them or replace them. If you clean them you could be creating a problem for yourself further down the line when the one small area you missed with the grease wears out and the bearing fails.
If it were me, and I wanted to do the job properly, I'd just replace the bearings.
PostPosted: 13:36 - 01 Sep 2011    Post subject: Reply with quote
I don't thing that's an issue - the grease will be spread about all the contact surfaces when the bearing starts turning.
The last post was made 14 years, 226 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.52 - MySQL Queries: 13 - Page Size: 51.79 Kb
