Tyres
Quirky
PostPosted: 16:37 - 01 Sep 2011    Post subject: Tyres Reply with quote
Afternoon
Just got home to find what looked like a small piece of metal embedded in my back tyre. I probably should have left it alone but I pulled it out and it was actually a inch nail at an angle.
There doesn't seem to be a puncture but I realise it might be slow so I could find a flat tyre in the morning. If it's not flat later on should I assume all is ok or could this have caused a 'weak' spot in the tyre?
I don't mind buying a new one but if i dont need to I don't want to waste money, the tyre's only covered 200 miles.
Cheers
Craig
MarkJ
PostPosted: 16:44 - 01 Sep 2011    Post subject: Reply with quote
I'd check in the morning to be sure. Put some water over the hole and see if it bubbles.
Quirky
PostPosted: 16:55 - 01 Sep 2011    Post subject: Reply with quote
You reckon if there's no sign of air leaking in the morning it'll be safe to ride on? I'm just thinking if it was close to going all the way through riding on it might finish it off?
No idea though, i'm just guessing really
salty21
PostPosted: 17:07 - 01 Sep 2011    Post subject: Reply with quote
i had exactly the same thing happen to me last week, went through at an angle but was about 2 inches long, i've got no idea how it didnt go through but im still using it and it's fine.
depending on the size of the tyre i may be interested in buying it off you if you didnt feel confident keeping it, i have a pretty low standard of personal safety and not a lot of money so i dont mind taking the risk Laughing
Quirky
PostPosted: 17:13 - 01 Sep 2011    Post subject: Reply with quote
The tyre's a 180/55 BT014 but hang fire I'll see what it's like in the morning.
I can see me being dubious about using it though, I'd be pretty gutted if I binned the bike for the sake of a new tyre.
Acemastr
PostPosted: 18:18 - 01 Sep 2011    Post subject: Reply with quote
the actual carcass of the tyre keeps the air in, not the tread, as long as the inner membrane that holds the air hasn't been punctured or slit then you're good to go.
...or so a bike tyre place told me.
2016 Toyota Tacoma Limited
Quirky
PostPosted: 18:25 - 01 Sep 2011    Post subject: Reply with quote
Well I've checked with some water and there was zero bubbles so hopefully the nail didn't go through. I'll leave it for the night and see if the pressure's dropped in the morning.
jimbothe
PostPosted: 18:40 - 01 Sep 2011    Post subject: Reply with quote
There's a legend in the making, right there. Thumbs Up Laughing
Check out our tackle shop on Facebook:
https://www.facebook.com/#!/JklTackle
Harris Tweed
PostPosted: 20:31 - 01 Sep 2011    Post subject: Reply with quote
Yep, similar story here too. Looked like a blunt piece of nail which was long enough to make me concerned that I would have a puncture when I pulled it out. However, three weeks of tyre checking and everything is still ok. Glad to read about the inner membrane explanation as it's clear it didn't go all the way in. After taking it steady I'm now doing my normal speeds.
KH125Ex-L1 (1984). Past: GSX750, BMW F650; ER500; GN400; KH125Ex-L1 (again).
PostPosted: 21:14 - 01 Sep 2011    Post subject: Reply with quote
A thing to bear in mind. A cut in a tyre can hold dirt. Dirt/grit can make the cut deeper/bigger. Cyclists often get more punctures in the wet when the grit gets a chance to work it's way in.
Marmalade
PostPosted: 21:41 - 01 Sep 2011    Post subject: Reply with quote
You'll be fine - flw
I had a nail go through a 2 week old tyre on friday, plugged it there and then and got on my way.
1000 miles later and it's still up and been doing some silly speeds on it.
I got some mushrooms here to fix it but thinking i'll just leave it be since there is only another couple of weeks on it and it's not losing any pressure
The last post was made 15 years, 21 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.55 - MySQL Queries: 13 - Page Size: 69.59 Kb
