Converting a van to securly carr motorcycles
hornetmike
PostPosted: 10:47 - 05 Sep 2011    Post subject: Converting a van to securly carr motorcycles Reply with quote
We want to convert our parts van a work (Merc long sprinter) to pick up customer motorcycles, the bikes are probably going to be new so we will need a fool proof system rather than a ramp and straps we would use for our own bikes.
Has anyone got any experience with any companies that can supply/convert our van ?
87 Honda CG 125 - 97 ER5 - SR 50 -81 Z250- 96 CBR 600 F- 94 GPX600R 88- GPX 400R- 87 GS 125 - 2006 Honda CB600F- 2003 ER5 - Honda CBF 1000 2009 - Honda CBR 600 RR 2011
Current BMW R1200GS 2010
PostPosted: 10:58 - 05 Sep 2011    Post subject: Reply with quote
ramp, straps and some mattresses Wink
Germ
PostPosted: 11:18 - 05 Sep 2011    Post subject: Reply with quote
He wants to make a transporter for motorcycles not a mobile dungeon Wink
Just did a quick google for "commercial vehicle interior fitters" and first link was to https://www.van-conversion.co.uk/ but there was a load more listed so you might find one clos to you by doing the same search.
PostPosted: 11:19 - 05 Sep 2011    Post subject: Re: Converting a van to securly carr motorcycles Reply with quote
Ramp and straps really should be 'fool proof'.
Ok, by the definition, they're not. But a much better solution would be to ensure it's not a fool using them Wink.
I would look to get some proper d-rings put in appropriately spaces on the floor. The problem with straps tends to be finding somewhere appropriate in the van to tie them to - if you've got some proper d-rings nicely spaced, you should be able to hold them very securely.
You could consider a tail lift etc, but I really don't think it's worth paying for a conversion - and even then, definitely not 'fool proof' - as I've seen fools drop bikes off them Smile.
Marmalade
PostPosted: 11:27 - 05 Sep 2011    Post subject: Reply with quote
You can get decent van wide ramps that you could ride up or maybe a little electric winch for ease of non runner loading.
Bump lock at the front for securing front wheel and a strap either side for security or a bump lock on wheels like the AA use for clamping in front wheel and then winch the lot in and secure once loaded
https://www.nurburgring.org/trip_reports/ring_trip5_pic02_bumplok.jpg
Suntan Sid
PostPosted: 11:32 - 05 Sep 2011    Post subject: Reply with quote
Why not use a bike trailer?
hornetmike
PostPosted: 11:38 - 05 Sep 2011    Post subject: Reply with quote
that bump lock looks good, simply cheapish. As its customer bikes we've can't let the bike have a chance of falling over.
PostPosted: 11:41 - 05 Sep 2011    Post subject: Reply with quote
Always a chance you could roll the van Wink Or get hit up the arse/side etc.
Im sure straps and the like will see most of the issues away. Just pad the van out like a boss Laughing
PostPosted: 11:44 - 05 Sep 2011    Post subject: Reply with quote
Much prefer bikes in a van, given the chance. Don't get any damage from road debris, weather etc. If the worst happens, they stay inside the vehicle.
I had my bike on one of those bump lock thingies on a trailer, when I got a puncture the other day.
It wasn't tied down that great (recovery bloke) and came out of the wheel holder, because the tie down had pulled it back a bit.
Good tieing down still needed, which begs the question of why bother with it in the first place.
Personally, I would trust 4 correctly-used straps over two and apparatus like that.
PostPosted: 11:59 - 05 Sep 2011    Post subject: Reply with quote
If it were my bike going into or coming out of a van, I'd like to see it being held up by something more than Darryl the Apprentice and his millisecond attention span. +1 to the winch and some kind of secure dolly.
Nixon
PostPosted: 12:06 - 05 Sep 2011    Post subject: Reply with quote
Slightly off topic but have you looked into insurance for this type of venture?
A company I worked for explored it and found that getting the right insurance would cost immensely more than any business it could produce ... as in £3000 just to transport on top of their premises and traders insurance. That was not including insuring the van either, just for transporting bikes in the back.
There were policies that would insure a "generic" load for a lot less, but expressly prohibit the transport of vehicles or vehicle parts, so if it did go wrong you would have no cover at all. Just a heads up Thumbs Up
[edit] If you have found insurance cheaper who is it?? Wink
Germ
PostPosted: 12:17 - 05 Sep 2011    Post subject: Reply with quote
How about buying a second hand horse transporter and doing that out? They already have a ramp at the back and sturdily built.
PostPosted: 12:21 - 05 Sep 2011    Post subject: Reply with quote
If it were my bike coming out of a van, I'd expect the staff to know enough about bikes to load them in a van, otherwise I'd be even more concerned about how it was put together Wink.
Gazdaman
I did a trackday!!!
PostPosted: 12:58 - 05 Sep 2011    Post subject: Reply with quote
Exactly this, except you can get ones that bolt to the floor. Get a decent quality folding metal ramp, wheel it in, pop it in the holder, strap it down to some proper D loops on the floor. Bingo. Perfect.
Gaz
PostPosted: 14:32 - 05 Sep 2011    Post subject: Reply with quote
Those bump locks are good.
You should really need nothing more than that and a ratchet tie-down on the end of each handlebar. Those tube ones that slide over the bars are least likely to mark anything.
Most people stick another tie-down across the saddle but it shouldn't really be necessary.
PostPosted: 14:57 - 05 Sep 2011    Post subject: Reply with quote
All the bikes I've had delivered/picked up or moved myself have only ever used tie downs. You don't need these bump stop things if you know what you're doing.
Marmalade
PostPosted: 18:26 - 06 Sep 2011    Post subject: Reply with quote
There are loads of people moving bikes and saying 'fully insured' when they simply have a goods in transit policy costing £200.
Bikes are not goods, they are vehicles,
I was paying £2700 for a motor trade policy to cover bikes and cars about 7 years ago on my truck before i packed it in.
I had a cbr1000 on a trailer in a bump lock with 2 straps and the trailer lost a wheel on the m5.
Bike stayed exactly where i put it and no damage.
Needed to change my pants though
djr
PostPosted: 22:14 - 06 Sep 2011    Post subject: Reply with quote
rescue24 (the company that carole nash breakdown use) have one of the bumplock type things, Mounted on wheels. (if they choose to use it) they chuck it at the bottom of the ramp, Push bike in, Ratchet bike in place then a winch pulls it into the back of the van (up an extra wide ramp) then they just tie it in place, Job done.
That's what i'd do if i were using it every day (and importently... Carrying heavy bikes (goldwings/heavy beamers e.t.c) even to be fair loading my sprint st onto a trailer on my own was a PITA and van would obv be higher (although wider ramp you'd be able to run up with bike anyway)
Should have a picture of the winch thing they use - will try and dig it out tomorrow.
PostPosted: 00:21 - 07 Sep 2011    Post subject: Reply with quote
I loaded a R1200GSA with a flat tyre in to my van (and out again) just fine on my own with a single ramp. If it's someone doing it regularly (as I have done in the past with racing, etc) it really shouldn't be a problem,
I'd expect the same of a bike properly tied down with 2 straps on a trailer without it.
Mrjoolz
PostPosted: 09:01 - 07 Sep 2011    Post subject: Reply with quote
Watch re runs of Street Hawk, and see if that gives you any ideas ?! Laughing
The last post was made 15 years, 44 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.67 - MySQL Queries: 13 - Page Size: 112.22 Kb
