| skatefreak |
 skatefreak World Chat Champion
 Posted: 00:02 - 05 Sep 2011 Post subject: over oiled 2 smoke dead :( |
Hey all,
so i swapped the old engine back in (honda NSR125 RY) and when it was in i started it first compression and ran great but was not smoking atall so in a panic i pulled the oil pump cable to full.
Sure enough it started to smoke after a few mins and all was good.
Stopped the engine and finnished putting her back together.
The i tryed to get her going again, lots and lots of smoke each time i tried to run the bike, it would struggle but i figued it would burn it off, eventually it seemed to give up.
I have had the carb appart and cleaned the jets incase some oil got in there and blocked them, put fuel directly into the engine to try flush out any oil in there but the bike doesnt even fire up now.
Really really winding me up, there is fuel (wet plug, put some down the spark plug hole) and deffinatly a spark which doesnt half smarts (bump starting it so went by feel, then checked the colour, a healthy blue) and i know the final element is air but not sure how i could check that (everything seems free flowing).
The bike doesnt even seem to try firing anymore. I know it sounds rediculous as all the elements *seem* to be there so what am i missing here
Any thoughts would be much appreciated.
Best regards
-Jvr |
| at106 |
 at106 Brolly Dolly
| skatefreak |
 Posted: 09:19 - 05 Sep 2011 Post subject: |
removing the air filter is one step i havnt tried but i have bumped this bike so many times in the past 48 hours the chain has streched a little
At first it would run but really rough, i have flushed the bottom end with plenty of fuel and now it just doesnt run.
I have a horrid feeling its an ignition bug as i smell fuel but i know there is a spark.
Could it just be that there is to much oil in the fuel still?
Best regards
-Jvr |
| serlant |
 serlant Brolly Dolly
| skatefreak |
 Posted: 09:42 - 05 Sep 2011 Post subject: |
Spun it over quiet a bit without the plug in and it turns over okay...
Anyone think exessive amounts of oil could have caused the compression to foul the head gasket? Radiator is slightly down since i put the engine in which could be down to 1, air pocket filling once i started it or 2, fouled head gasket
Have topped it up, going to push it around some more and see what happens ...
-Jvr |
| SuzukiTom |
 SuzukiTom Nova Slayer
| skatefreak |
 Posted: 10:24 - 05 Sep 2011 Post subject: |
hey,
dont have a compression tested but this engine ran like a champ before the engine swap and after i put the engine back in it started up first compression so i wouldnt have thought it would be an issue.
That being said i dont have a compression tester nor do i know anyone local who does
May have to make a trip to the bike shop, get a new plug and see about a compression tester i guess...
Update on the engine, pushing it halfway down the road in first gear and it fires a couple of times on and off so at least its now trying.
I have cleaned the jets, not fiddled with anything else so a little unsure as to what it could be now.
i havnt played with the mixture appart from messing with the oil pump which is now at factory settings...
Am going to have a sit down, mighty knackered
Best regards
-Jvr |
| SuzukiTom |
 Posted: 10:55 - 05 Sep 2011 Post subject: |
hmm, worth seeing if you can beg borrow or steal to try it out. just to make sure your not flogging a dead horse.
anyway might be worth popping the exhaust header off and having a proper look in there to make sure its not totally gunged up!
do you skate street or park?  |
| MarJay |
 MarJay But it's British!
| skatefreak |
| SuzukiTom |
| skatefreak |
 Posted: 11:16 - 05 Sep 2011 Post subject: |
Yep,
I think you're spot on there but there a supprise issue now
Got the engine running, revved up, sh*tloads of smoke (crankcase must have been saturated), but yes.
So engine gets going and running okay ish, suddenly cuts out and i think okay, push back and lift the tank to pull out the plug then i smell petrol... lots of it, and then hear it and its pissing out under the bike from the float bowl drain (theres a breather in there).
Either the float is stuck/inlet valve has something holding it open or the float valve level has spontaniously somewhere between starting and it dieing.... (impossible i would have thought).
Confusing, carb out time
-Jvr |
| 0l0dom0l0 |
 0l0dom0l0 World Chat Champion
 Posted: 11:45 - 05 Sep 2011 Post subject: |
| skatefreak wrote: | Either the float is stuck/inlet valve has something holding it open or the float valve level has spontaniously somewhere between starting and it dieing.... (impossible i would have thought).
-Jvr |
Since when did 2 strokes have inlet valves? ____________________ CBT Passed: 30/08/2009, Theory Passed: 31/08/2010, Mod 1 Passed: 6/9/2010, Mod 2 Passed: 13/09/2010. Restriction ended 13/09/2012.
Bikes: 2007 Derbi GPR 50, 1998 Yamaha Fazer 600 (written off), 2002 Yamaha Fazer 600, 1994 CBR 600F, 2003 Triumph Daytona 600, Kawasaki ZX6R J1.....Current: 2006 Yamaha FZ6, 1998 Suzuki TL1000R and a Honda VFR 400 NC30. |
| skatefreak |
| skatefreak |
 Posted: 14:09 - 05 Sep 2011 Post subject: |
bought a compression tester, the first 3 tries told me all i needed to know...
110psi exactly each and every time... Its a little down on the reccomended 125+ but it should still have some go in it...
I would throw on the spare top end but i'm not sure what size the piston/rings are and if i swap the cylinder i dont have a fresh gasket
Wondering if it's worth having a bash at swapping the top end, using the old gasket for now?
-Jvr |
| Kickstart |
 Kickstart The Oracle
| skatefreak |
 Posted: 14:58 - 05 Sep 2011 Post subject: |
yeah,
I wont know the piston size untill i get the top end off though...
I can see a rebuild soon would be a good Great idea but I still dont think its the underlying problem here...
The behaviour is now this:
Clean oil/fuel off plug,
plug in,
bump (it runs for 10-15 seconds without fail at this point and then dies)
Repeat cycle.
Regardless of how long its left, without wiping the plug it wont start but once wiped it will still die again. The plug comes out wet with what appears to be a reasonable amount of oil over its surface...
I've been doing this for the past 15-20 mins whilst waiting to pick up a new standard plug, i've been trying both an NGK and iridium (likes the iridium a lot more) to be sure all the oil is out of the system. Its smoking a little less now (a little closer to normal) but keeps dieing...
Seems like the classic symptoms of fuel starvation but i cant see how this can be as I have not changed anything in the carb (asside cleaning it out etc).
Its a lot better now than this morning, its more responsive and doesnt just moan at throttle inputs without accelerating but its still dieing.
Cup of coffee and i'll get on my push bike to pick up the new standard NGK plug.
Best regards
-Jvr
Ps, a rebuild will be on the books for the near future, and a new(weemoto knockoff)/second hand starter as mines beyond repairing  |
| andy_uk |
 andy_uk World Chat Champion
| skatefreak |
 Posted: 16:37 - 05 Sep 2011 Post subject: |
Hey,
Yeah, i had the throttle open.
Got the bike running, new spark plug made all the difference but it seems the con rod could be bent, there is some heavy vibration and the bike has lost a lot of power.
Will have a shot at a squish test and see how it pans out
Thanks for all the input guys.
Best regards
-Jvr |
| P.addy |
 P.addy Red Rocket
 Posted: 16:49 - 05 Sep 2011 Post subject: |
Ever thought the compression is low as the rings could be screwed... and its cutting out because it physically cant stay alive with such low compression. Simply popping the head and barrel off to look would be ideal
Friends RS became a slag to start after about 115psi... after a few more days it started shooting down and got to about 100 and needed a rebuild before it would fire up at all. |
| Robby |
 Robby Dirty Old Man
| devojunior |
 devojunior Brolly Dolly
| Germ |
 Germ Trackday Trickster
| Livefast123 |
 Livefast123 Nearly there...
| skatefreak |
 Posted: 11:49 - 06 Sep 2011 Post subject: |
No hat eating will be required,
A fresh sparky sorted it out and the engine is 'running' well asside further issues such as a suspected bent con rod.
I'll start a new thread about that but in conclusion it was just a cr@p load of oil in the crank case that buggered two plugs (one iridium ).
Lesson learnt = never underestimate the good a new plug can do for a two stroke!
Cheers for the input everyone and best regards
Jvr |
The last post was made 14 years, 199 days ago. Instead of replying here, would creating a new thread be more useful? |
