Pulsing from front wheel zzr600
Mrjoolz
PostPosted: 21:20 - 07 Sep 2011    Post subject: Pulsing from front wheel zzr600 Reply with quote
Rode into work this morning, all fine. Left the office to ride home and noticed a pulsing or grabbing at front wheel. Quite bad on motorway and brakes don't feel as good
What could the problem be. ? Warped discs? Wouldn't I have noticed this before rather than sudden change?
steven_191
PostPosted: 22:32 - 07 Sep 2011    Post subject: Reply with quote
A warped disc can happen at any time really. Excessive use and rapid heating and cooling doesn't help.
Is it definatelu the brakes? By grabbing I guess you mean some sort of resistance as if your pulsing the brake lever?
Unbalanced wheel maybe?
andys675
PostPosted: 23:03 - 07 Sep 2011    Post subject: Reply with quote
warped discs are common on ZZR600's, along with knackered back shocks and holey exhausts, but they're worth it!
Ariel Badger
PostPosted: 23:39 - 07 Sep 2011    Post subject: Reply with quote
Warped disk and/or sticking calipers. it just needs money chucking at it!
SoND
PostPosted: 09:59 - 08 Sep 2011    Post subject: Re: Pulsing from front wheel zzr600 Reply with quote
Your brakes could be working fine, piston goes out, piston goes in and over time it goes back in only slower and slower until one day it got just enough dirt on it to stop it going back in far enough and BAM you have a dragging brake overheating your disc.
Clean your brakes before shelling out for discs.
Mrjoolz
PostPosted: 11:51 - 08 Sep 2011    Post subject: Reply with quote
I have checked the discs (heat wise) when getting off and they aren't hot at all. I cant feel the pulsing through the lever, but through forks and front wheel only
PostPosted: 11:55 - 08 Sep 2011    Post subject: Reply with quote
If you can't feel it through the lever I would suspect the disks are not warped. Not sure what you are feeling through the forks, but could still be disk related if they are contaminated (oil on them, or a pad having stuck to one and left a residue). However I would also check the wheel bearings and also for any wheel weights that are missing.
Mrjoolz
PostPosted: 20:09 - 08 Sep 2011    Post subject: Reply with quote
Got home tonight and check discs straight away. Nearside rotor Luke warm, offside cold.
The last post was made 15 years, 51 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.96 - MySQL Queries: 13 - Page Size: 55.07 Kb
