offering advice on brakes
Retro-Man
PostPosted: 12:08 - 30 Aug 2004    Post subject: offering advice on brakes Reply with quote
Hello all
My mechanical forte is brakes, how they work what they do and how to fix em properly!!!
any questions post a note Question Question Question Question
https://domharnessphotography.webs.com
mr.z
PostPosted: 22:47 - 30 Aug 2004    Post subject: Reply with quote
okeydokey, you asked for it Razz
Do you know allot about drum brakes? the other night i noticed the rear brake is not totaly constant, it dosent pulse noticably i could only really feel the effect when drifting allong, i'd been exprianceing some wobbleings arround country lanes recently and put it down to bushes being worn or something...
So apparently this means the drum is warped slightly? do you know of anywhere who would be able to skim it back into shape? its a pritty specialist job i'd imagine?
Just wondering really, its not major but i'd like to sort it next time the wheels are off, also i dont buying a new drum would cost alltot anyways Very Happy
How much of a jolt would it need to cause damage to the drum?
Thanks for reading Wink
Retro-Man
PostPosted: 20:09 - 31 Aug 2004    Post subject: Reply with quote
o.k first you say it wobbles around country roads
is this whilst braking Question
I'm not convinced this is entirely a brake issue first check all wheel/suspension fixings for tightness check all bushs for play
If it is a brake issue you can first try to buff up the shoe surface evenly using sandpaper.
whilst shoes are out, inspect friction surface of drum for signs of heavy or non contact this may show itself as areas of blueing or darkened areas(corrosion).
also inspect exterior of drum for cracks/ pieces missing, a lot of drums have cooling fins if any of these are broken /missing then drum may have warped due to overheating.
brake drums will also have a max amount of wear, this is difficult to measure without the correct device but as a generale rule of thumb if the drum has a ridge/lip around the edge of over 1mm the drum is worn out..
as to re machining I would not advise it as if warped the amount needing to be machined off will without doubt make the drum to thin.. as such it wont dissipate the heat generated by braking(frictional heat) and you will be in a worse situation within several miles.... it will work out cheaper to buy a new drum... note also change shoes at same time if changing drum is required.
hope this helps Thumbs Up
binge
Emo Kiddy
PostPosted: 23:30 - 02 Sep 2004    Post subject: Reply with quote
Ive got a question!
On my speedfight the rear brake keeps locking on, pretty tight too.
It is a disk brake, and there are no score marks on the disk, and the pads are not worn out, theres a lot left on them.
The brake will be fine for ages, then all of a sudden, it will tighten right up and the bike wont goe very fast...
Any ideas?
Thanks... Ben
mchaggis
PostPosted: 02:05 - 03 Sep 2004    Post subject: Reply with quote
Here's a classic... Squeaky front drum brakes on a CG125. Squeak at low speed to start with, but squeaking dies down after time and higher speed. Dust in the drum, moisture in the drum? Or perhaps a leading edge of the shoe needing chamfered? Any ideas?
Thinking
:editted for grammar.
Retro-Man
PostPosted: 17:01 - 04 Sep 2004    Post subject: Reply with quote
binge
sounds like the pads are jamming in the carrier a removal clean and refit should fix also check free movement of caliper pistons
Idea
Retro-Man
PostPosted: 17:03 - 04 Sep 2004    Post subject: Reply with quote
mchaggis
all of the above plus possible glazing of the shoe friction material, easily sorted with a piece of sandpaper.... Idea
steve09
PostPosted: 23:52 - 04 Sep 2004    Post subject: Reply with quote
I got a piaggio typhoon.
drum brakes at the back some times when ive stoped at the lights i accelrate off the lights and i can feel the back sticking and i have to revf it alot then it sorta comes unstuck and jumps forward
Retro-Man
PostPosted: 13:02 - 05 Sep 2004    Post subject: Reply with quote
steve
I take it this drum brake is operated by a cable/rod assembly
first make sure cable is oiled and is releasing correctly same goes for the rod attached to the drum arm if fitted..
if all the linkages are free moving and well lubed then you probably need to strip out the shoes for inspection, clean refit and adjust.
hope this helps pm me if detailed help is required Thumbs Up
steve09
PostPosted: 13:05 - 05 Sep 2004    Post subject: Reply with quote
thanks ill try that today let ya know how i get on
Retro-Man
PostPosted: 17:40 - 05 Sep 2004    Post subject: Reply with quote
no worries m8 Thumbs Up
ZRX61
Victor Meldrew
PostPosted: 22:52 - 05 Sep 2004    Post subject: Reply with quote
Ok, heres one:
I was pulling apart the rear end on my '64 Galaxie 500XL on Friday & when I removed the right brake drum the linings fell out leaving the actual metal part of the shoes where they should be... The brake linings had just separated from the shoes.
What glue can I use to re-attach the linings to the shoes? Wink
Retro-Man
PostPosted: 23:01 - 05 Sep 2004    Post subject: Reply with quote
fuck no Shocked
do not reattach linings
new linings required
the original means of attaching friction lining to shoe plate may be either very specialist rivets or specialist adhesive
I suspect the reason for them coming off is that they are almost worn to the metal or very old
worn brake shoes are easy as they have the same general limit as car tyres 1.6mm of material. specific bikes may vary depending on spec but 1.6mm is a good rule of thumb
ZRX61
Victor Meldrew
PostPosted: 18:22 - 06 Sep 2004    Post subject: Reply with quote
Retro-Man wrote:
fuck no Shocked
LOL! I was kidding, already ordered new shoes (11x 2 1/2 in). The old ones were glued on, not riveted & one side had separted from old age I guess. Hardly any wear on em tho, still about 3/16th material left.
Never seen so mnay parts inside a brake drum in my life & that includes the aircraft I've worked on. Gonna do one side at a time so I can use the other side as a *Chinese blueprint* even tho I have the factory manuals Smile
And as an added bonus I finally get to use the set of pro brake tools I bought last year Smile
Claud 14.7 to 1
PostPosted: 18:51 - 06 Sep 2004    Post subject: Reply with quote
How much meat should there be on my pads before i change them?
And because my calipers are not opposed pistion. Its a 2 piston sliding caliper, does this mean that the meat on the "piston side" will wear faster then the other side. I cannot see the wear on the piston side... Rolling Eyes. So i kinda need to guess by looking on the other side. Rolling Eyes
Cbr400 '92
Thank you!
ZRX61
Victor Meldrew
PostPosted: 18:56 - 06 Sep 2004    Post subject: Reply with quote
Most brake pads have grooves in them, ya supposed to change em when they are worn down to the groove.....
However.. some pads don't have grooves in them (Kawasaki Z1/Z900 etc) They have a red line painted on the edge of the pad material instead Smile
Claud, just pop the caliper off & have a look, only takes a couple of minutes.....
Claud 14.7 to 1
PostPosted: 19:36 - 06 Sep 2004    Post subject: Reply with quote
Thanks. The pads dont have any wear indicators, but if you get underneath the bike and look "up" the caliper you can see the meat left.
The side nearer the piston looks like it wears slightly faster, but its hardly noticable, both pretty much the same. Ive got a few mm left so it'll be alright but i'll keep an eye on them. Thumbs Up
gsxrboy
PostPosted: 01:23 - 09 Sep 2004    Post subject: Reply with quote
I have a crappy bike i bought just to sell again from ebay, cb350s, unless anyone wants it then its a minter!! the front discs are shot in a big way and need replacing. I can machine pretty much anything and don't wish to pay £90 each.
what the hell are they made of??
Cheers chief Mr. Green
Retro-Man
PostPosted: 19:59 - 09 Sep 2004    Post subject: Reply with quote
don't even think about it...
tolerances are minimal any more than 0.015mm warpage will result in brake vibration...
skimming the discs below minimum thickness will result in poor frictional heat dissipation resulting in brake vibration
sorry if thats not what you want to hear
material depends on make but will have a high content of steel
Big Pete
PostPosted: 13:07 - 10 Sep 2004    Post subject: Reply with quote
honda discs tend to be made of stainless steel, no idea what grade. Flat discs can be laser cut from sheet and dressed up to suit.
I have had discs ground to 0.5-0.6 mm undersize with no probs at all but they were still 4.0 mm thick after being ground.
If you decide to make your own discs its a good idea to use dye penetrant on the plate before cutting so you know there are no cracks.
Trust me, I`m an engineer
GarageOfPower.co.uk
jay12329
Dr. Evil
PostPosted: 13:18 - 10 Sep 2004    Post subject: Reply with quote
Towards the end of the silverstone track day my brakes became spongy, the bike was then sat for about an hour and they were nice and responcive which lasted all of 10mins. What is going on?
Bike is a hornet 6.
J
Retro-Man
PostPosted: 18:23 - 10 Sep 2004    Post subject: Reply with quote
you are suffering from classic brake fade, as brake fluid ages it absorbs moisture this property is refered to as the fluid being hygroscopic..
all you need is fresh brake fluid
brake fluid has a boiling point somewhere around 160 degrees centigrade
1% of water redusces this point by 20 degrees
when the brakes get hot after thrashing round the track all day the fluid boils and turns to gas, gas is compresssable fluid is not.
change the fluid
remove the problem
jay12329
Dr. Evil
PostPosted: 19:24 - 10 Sep 2004    Post subject: Reply with quote
But the bike is only 5000miles and 12months old. Honda advise that brake fluid and lines will last at least 4 years.
J
Retro-Man
PostPosted: 20:01 - 10 Sep 2004    Post subject: Reply with quote
theres always one clever dick
did you tell me this the first time round ....NO......
where is the bike kept, brake fluid will seek out moisture wherever it can find it.
are all those miles dry miles Question
and I dont care what honda say brake fluid has maximum life of two years Thumbs Up
ZRX61
Victor Meldrew
PostPosted: 21:41 - 10 Sep 2004    Post subject: Reply with quote
Picked up my new Galaxie brake shoes this morning, $16.00 for the rears & the shop had the parts (for a 40 year old Ford) sitting right on the shelf.
The last post was made 21 years, 362 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.61 - MySQL Queries: 13 - Page Size: 128.95 Kb
