Oil API
Chriss
PostPosted: 14:03 - 08 Sep 2011    Post subject: Oil API Reply with quote
Hi,
I'm about to do an oil change. Haynes says it needs 10w 40 of SF or SG specification. Must it be SF or SG, or will SL or SJ suffice?
Thanks
TheShaggyDA: I've got 3 or 4 pairs that predate my wife, so at least 11.5 years old.
PostPosted: 14:13 - 08 Sep 2011    Post subject: Reply with quote
In theory the higher grades are meant to be backwards compatible (with SF and SG being obsolete).
In practice some of the newer grades have limited the amounts of some rather useful additives which are harmful to catalytic converters.. Further some of the oils with newer grades contain friction modifiers that some wet clutches object to.
To a large extent it comes down to the particular oil you use. I have certainly used SJ oils before.
Chriss
PostPosted: 14:20 - 08 Sep 2011    Post subject: Reply with quote
Thanks
As long as I stick to motorcycle oil, that shouldn't be an issue, should it?
PostPosted: 14:25 - 08 Sep 2011    Post subject: Reply with quote
Shouldn't be an issue with them.
The last post was made 14 years, 165 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.95 - MySQL Queries: 15 - Page Size: 40.98 Kb
