Car Oil in a Bike?
HD
PostPosted: 00:28 - 09 Sep 2011    Post subject: Car Oil in a Bike? Reply with quote
Right, I know there are loads of threads about this but just want to make sure as it is going to be a long term bike.
Will using a car oil in a bike do any harm? (aslong as it doesn't have friction modifiers, I know about that)
The oil in question is Mobil 1 as a friend can get it for cheap.
Just want to double check, like I said.
Cheers Thumbs Up
johnsmith222
PostPosted: 00:35 - 09 Sep 2011    Post subject: Reply with quote
Go for it. I always use semi synthetic 10w40 car oil.
ws4936
PostPosted: 00:59 - 09 Sep 2011    Post subject: Reply with quote
Castrol GTX, 14 squids at costco for 4 ltrs
If everything seems under control, you're just not going fast enough.
temeluchus
PostPosted: 03:20 - 09 Sep 2011    Post subject: Reply with quote
I've used car oil to good effect. Avoid fully synth.
brands used:
carlube 15/40
halvoline premium 15/40
GTX high mileage 15/40
comma highway 20/50
PostPosted: 07:31 - 09 Sep 2011    Post subject: Reply with quote
Why take the risk if the bike is a keeper?
Your talking a few quid every 5000 miles.
Halfords semi synthetic bike oil, 18 quid for 5 litres.
temeluchus
PostPosted: 07:58 - 09 Sep 2011    Post subject: Reply with quote
top end on my fj1200 was fine and showed no apparent wear when I did the camchain at 80k odd. It had done 30k on halvoline premium.
I suspect it will be fine for a bandit 400.
if money was no object we would all using Krytox.
PostPosted: 09:42 - 09 Sep 2011    Post subject: Reply with quote
Used car oil in bikes loads of times (including fully synthetic). Only one that gave clutch issues also gave clutch issues with new plates and bike specific oil.
HD
PostPosted: 10:06 - 09 Sep 2011    Post subject: Reply with quote
I do oil changes about every three months anyway.
Why not fully synth?
I think its semi anyway.
So the general consensus is it will be fine then.
lihp
PostPosted: 10:23 - 09 Sep 2011    Post subject: Reply with quote
I use Castrol GTX in the R6, and service at normal intervals. Not noticed any difference.
temeluchus
PostPosted: 13:47 - 09 Sep 2011    Post subject: Reply with quote
Can have friction modifiers that mess up wet clutches.
Avoid anything with "energy conserving" on the tin as well.
PostPosted: 13:57 - 09 Sep 2011    Post subject: Reply with quote
Any oil can have friction modifiers, irrespective of whether it is synthetic or not.
That said a big advantage of synthetic oil is that less additives are required to give it a decent viscosity range, and it is these additives rather than the oil itself that wears out. So a synthetic oil should last far longer, but with the nominal mileage it is thrown away at on bikes this isn't really a gain.
HD
PostPosted: 15:55 - 09 Sep 2011    Post subject: Reply with quote
So aslong as it hasn't got friction modifiers, chuck it in?
Chriss
PostPosted: 16:43 - 09 Sep 2011    Post subject: Reply with quote
Out of curiosity, what is it you're looking for? Magnatec can't be used in bikes with a wet clutch, but it doesn't specifically say it has friction modifiers.
Thanks
TheShaggyDA: I've got 3 or 4 pairs that predate my wife, so at least 11.5 years old.
Quornholio This post is not being displayed because the poster has bad karma. Unhide this post / all posts.
felicity
PostPosted: 17:04 - 09 Sep 2011    Post subject: Reply with quote
Would it be obvious if the "wrong" oil was used? (Clutch not working properly, etc.?)
I just put some 10W40 synthetic car oil in my bike; didn't notice until I'd already changed it that it's rated SJ, while the manual says to use SH. (It's not energy conserving, though.)
bombom
PostPosted: 19:02 - 09 Sep 2011    Post subject: Reply with quote
im on castrol 10/40's in my bandit and its fine pal (i get the stuff freeeee!)
Current: 97 zx6r f3
Previous: suzuki gsf400 bandit
HD
PostPosted: 19:25 - 09 Sep 2011    Post subject: Reply with quote
The oil is Mobil not magnatec dude Thumbs Up
And looks like I will too Razz Shhh! Shhh!
Tweet
PostPosted: 19:37 - 09 Sep 2011    Post subject: Reply with quote
I used Carlube semi snythetic in my VFR for years with no ill effect or clutch slip.
£12 from our local motor factor. Thumbs Up
0l0dom0l0
PostPosted: 19:54 - 09 Sep 2011    Post subject: Reply with quote
I've used Wilkinsons 10w40 in both my bikes and never had a problem. Infact, they both love it!
£13 for 5 litres isn't bad either. The Honda's going to live on it from now on Very Happy
old1eye
PostPosted: 20:08 - 09 Sep 2011    Post subject: Reply with quote
just to add my 2 pence worth, i run caster oil in my c90 and its fine. also i put slick 50 in my honda shadow 25,000 miles ago and its superb and i run car mineral oil 10/40 in it too with a change every 1,500 miles
If its loud Be proud!
LongJohn22
PostPosted: 22:37 - 09 Sep 2011    Post subject: Reply with quote
I've always used supermarket 10W/40, cheap as chips and no problems whatsoever. I do tend to change it rather more frequently than the service schedule recommends though.
kestrel
PostPosted: 23:44 - 09 Sep 2011    Post subject: Reply with quote
My old xs650 hack gets any 10w40 that's cheap and remotely oily. The 748 gets Motul 300V Factoryline 10w40 Fully Synth, as recommended by the local engine builder.
Isle of Man.........Road Racing Capital Of The World
temeluchus
PostPosted: 11:10 - 10 Sep 2011    Post subject: Reply with quote
Its one of the reasons Krytox is so bloody good, shame its 100 quid a litre.
I am tempted to get some for my gearbox and final drive, it should outlast the rest of the bike.
Gazdaman
I did a trackday!!!
PostPosted: 14:23 - 10 Sep 2011    Post subject: Reply with quote
I always use the cheap shit 10W/40 car oil from Halfords. Even more so if it comes with a set of free screwdrivers.
Never any problems from me.
Gaz
battleaxe
PostPosted: 20:57 - 11 Sep 2011    Post subject: Reply with quote
used halfrauds semi for years, the present zzr 1400 has covered 26000 to date on it and hope to cover many more
B-A
It's better to say nothing and appear an idiot, than open your mouth and prove the point
The last post was made 15 years, 15 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.95 - MySQL Queries: 13 - Page Size: 126.15 Kb
