| jacky230766 |
 jacky230766 L Plate Warrior
 Posted: 00:34 - 11 Sep 2011 Post subject: upping from 50cc to 70cc |
hi ,just need some advice,i got a gilera runner 53 plate,it had a leo vince exhaust on when i bought it and a split in the manifold (found out weeks after buying,) we had a few issues with power up hills,so checked out rollers and changed to lighter 5.25grms bike was working great until back wheel needed changing and numpty doing the job(at a motorcycle) garage snapped studs off,they wanted to strip engine as couldn't get into fix(also wanted £45 quid and hour) to fix,cutting long story - nephew said he could do it,but found it had already been done sometime before very badly so suggested getting 70cc kit,i did,it's now fitted and running but i have loss of power when riding ,comes and goes like belts streched or something,and wont pull up hill at all, main jet is at 72 ,do i need to do anything esle or is it a belt/gear problem,sorry for it to be long ut need advise as i've practially rebuilt this bike since buying in april, |
| Livefast123 |
 Livefast123 Nearly there...
| jacky230766 |
 Posted: 01:22 - 11 Sep 2011 Post subject: |
thank you for your advice ,yeah didnt think it was gonna be straight foreward,even though i've upped main jet to 72 felt it needs to be around the 85 mark the rollers were changed from standard 9grams to 5,25 grams and this worked great with the exhaust,until we found the split inlet manifold,bought an enki manifold and reed kit but manifold sat too low so had to resort to another run of the mill manifold,seeing as i didnt have the pulling problems that i've now got,untill kit was fitted,I thought about the gears etc,so probably needs springs doing will have to check up on that as i have no ideal what ones are needed,thank you again, |
| Livefast123 |
| MattWadz |
 MattWadz Trackday Trickster
| SpannerMonkey |
 SpannerMonkey World Chat Champion
The last post was made 15 years, 51 days ago. Instead of replying here, would creating a new thread be more useful? |
